Aster bracket users step inside
Old Apr 16, 2014 | 07:11 PM
  #121
zssman's Avatar
anyone tried running this with the sdce bracket, electric water pump, and a f1r? Just got the car. Made 1 pass, then alternater died. Then rain out. New to blowers, what do u guys think? Any assistance would be cool. Thanks, Phil.
Old Apr 16, 2014 | 07:20 PM
  #122
The Alchemist's Avatar
UNDER PRESSURE MOD
I heard the SDCE bracket was spaced away from the motor differently, so you would need to space the pulley differently as well.
Old Apr 16, 2014 | 07:35 PM
  #123
BTLBABY's Avatar
Not going to happen my man. You can't even run the factory ProCharger pulley on the SDCE with an electric water pump. I just swapped my electric out for a Vette LS2 pump last week. Just so I can run the 7.65 factory pulley. That's when I found out the bracket and pulley are spaced out about a 1/4" farther from the engine than the Aster and factory ProCharger bracket.
Old Apr 16, 2014 | 07:38 PM
  #124
zssman's Avatar
Thanks guys. Will have to see which pulleys on it.
Old Apr 17, 2014 | 08:27 PM
  #125
BTLBABY's Avatar
The only way you could get away with running a bigger crank pulley with the SDCE and an electric WP, is if you can run the pump with out the pulley on it. Then it would clear.
Old Apr 17, 2014 | 10:27 PM
  #126
zssman's Avatar
would I be able to do this if I had the aster bracket? Thanks.
Old Apr 17, 2014 | 11:00 PM
  #127
BTLBABY's Avatar
Not with the electric water pump. You still have to run a Vette LS2 water pump to run a crank pulley bigger than the 7.250 with either the Aster or SDCE. It's the belt rise coming off the top of the crank pulley that makes the water pump an issue.
The SDCE actually has less of a belt angle than the Aster, but still to much to clear the pump pulley.
Old Apr 18, 2014 | 01:23 AM
  #128
AbsolvedJD's Avatar
I can't use the CBR pulley because my waterpump pulley is offset too far forward I believe. The blower belt hits the front of the waterpump pulley with the CBR in place. You can see in the pic the distance from where the main belt rides in relation to the front of the WP pulley. It seems like the main drive belt rides too far back from the front lip of the WP pulley because the pulley is too far forward.
With the Procharger crank pulley installed the blower belt is below the WP pulley, so I never noticed a problem until I installed the larger CBR pulley(which is a nice piece of equipment btw).
Anyone else have this problem? I'd appreciate it if someone else with the Aster setup would take a pic of where the serp belt rides on their waterpump pulley.
Edit: I used a 53" belt on the close idler hole with a 3.85" pulley and it worked. Put me at 10 lbs of boost. I was seeing 8lbs with the Procharger crank pulley.
Old Apr 18, 2014 | 07:45 AM
  #129
stmz28's Avatar
Looks like you pulled the water pump pulley out a little to far. I have the 8.65 crank pulley on my car and it works fine.
Old Apr 18, 2014 | 08:01 AM
  #130
AbsolvedJD's Avatar
I agree. I wish there was a way to press the water pump pulley back, but I've read where Aster said it would just push the spindle out the backside of the pump.
Old Apr 20, 2014 | 08:51 AM
  #131
Firehawk441's Avatar
Old Apr 20, 2014 | 08:58 AM
  #132
Thanks for sharing this info. Hopefully Bob reads this and adds it to the list on his web page.
Old Apr 20, 2014 | 02:26 PM
  #133
AbsolvedJD's Avatar
He already has. And thanks for the pic! I'm might take the waterpump off and remove the back plate so I can push the pulley back on 1/8". Pretty sure they make a replacement gasket for the back plate. Then again it would be much easier to just use the Procharger crank pulley and get a smaller head unit pulley!
Old Apr 21, 2014 | 04:57 PM
  #134
95-1LE-Z28's Avatar
I'm using the stock J bracket with the 8.65 CBR pulley and a 4.13 blower pulley. The perfect belt length is 43.50"(K080435HD). Please add to the belt listing.
Old Apr 21, 2014 | 05:56 PM
  #135
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by 95-1LE-Z28
I'm using the stock J bracket with the 8.65 CBR pulley and a 4.13 blower pulley. The perfect belt length is 44" long(K080435HD). Please add to the belt listing.
KO80435HD should be a 43.50" belt. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 21, 2014 | 08:09 PM
  #136
95-1LE-Z28's Avatar
I was going off of the length noted on the Oreily's product page. Thanks for the correction though, i'll keep that in mind. Thanks
Old May 9, 2014 | 09:48 PM
  #137
98legendws6's Avatar
I have a complete SDCE setup and I am more than happy to allow you to use my stuff and be the Guiney Pig....In the process of Mocking up my built LS3 setup so I can send you anything you would need to ensure the pulley would work for us SDCE peeps.
Old May 11, 2014 | 08:49 PM
  #138
Chris@CBR's Avatar
Pm me with your phone# and a good time to call. I think I may can help you out here.
Old May 11, 2014 | 11:58 PM
  #139
conan's Avatar
I'm in for 1 if you guys make it happen.
Old May 12, 2014 | 08:21 PM
  #140
BTLBABY's Avatar
As am I!
Guess I'll hold off on moving my SDCE set up back if Chris is going to make a pulley for us. Keep us posted please sir!!
