Any one use the 1300hp thread stone IC?
Treadstone
17psi it gained 50* on a pull to 150mph
24psi it gained 80*
Garrett
18psi it gained 18*
26psi it gained 27*
31psi it gained 30*
Treadstone
24psi it gained 80*
Garrett
18psi it gained 18*
26psi it gained 27*
31psi it gained 30*
The tubulator density is identical inside and out on both, that being not dense
Only data i have is iat rise. I saw 42 deg rise on 24 psi boost thru master power t70's. 48 deg inlet 90 deg outlet into the intake. 3rd gear dyno pull, th400, 401" sbc 7k rpm, 1009 whp sae.
Seems to work well and i am likely near its max rating.
I only tracked the combo at 12 psi and saw 30 deg rise, 90-120 deg thru 3 gears on a 70 deg ambient day
