When is it considered too cold for boost?
Old Nov 27, 2013 | 11:23 AM
Wicked69's Avatar
Originally Posted by ajrothm
That's a classic vid I've had for years.... That stupid **** talking all that **** then gets beat by a stock 6 spd formula on the street... LOL
I did love the GN and hated to see it lose.
"I'm Kenne Belllll"..... LOL
Del, put the wood to the Chevelle... It will be fine.... Just don't wrack on it with a cold engine/oil... All my turbo stuff always ran a ton better in cold air.... Keep an eye on the afr the first pass and make sure the EFI is doing what it should be... Traction will be your issue...
I always warm the car up to 200degrees before I ever drive it first time of the day and never romp on it until its been driven for 10 min or so to get trans and gear fluid warmed up.
Thanks for the reply.
Old Nov 28, 2013 | 11:40 AM
trans2000am's Avatar
my car ran like a rape ape the last day the track around here was open was mid 40's
Old Nov 28, 2013 | 12:18 PM
rotary1307cc's Avatar
If you are running richer or leaner based on temperatures you don't have cylinder bias setup correctly.
It could be 200* intake temps or 40* and if the computer is setup correctly the fueling will be correct
Old Nov 28, 2013 | 12:32 PM
Wicked69's Avatar
I was just referring that the car is at operating temps before I just on it.
Old Nov 28, 2013 | 08:58 PM
Wicked69's Avatar
Well we had some fun today. Drove around and showed him how it works and then let him rape it on the highway doing some 15lbs pulls in high gear. Needless to say he had a blast!
They are thinking about opening the track on Saturday. If they do I feel cofident I can get a 5.70 pass. It's a big jump but I feel as though my tune is spot on now. We'll see. I guess the big question is if they can get the track to hold with the colder weather. Supposed to be 45 degrees.
Old Nov 29, 2013 | 10:01 AM
I know that was towards people that have air/fuel ratios that move with temp
Old Nov 29, 2013 | 11:32 AM
BMF_Racing's Avatar
Thumbs up
Good Luck man! Let us know how it goes.
Old Nov 29, 2013 | 09:17 PM
supra94tt's Avatar
As so many guys already mentioned--for turbo/supercharger apps, the colder the better, as long as you got traction and proper tune you should be ok.
Old Nov 29, 2013 | 09:38 PM
LS1NOVA's Avatar
Mine ran hard as hell today in 20 degree Minnesota temps. No traction makes for awesome rolling burnouts though.
Old Nov 29, 2013 | 09:59 PM
mrstepheneades's Avatar
Amen to rolling burnouts with no effort.
Old Nov 30, 2013 | 07:15 PM
Wicked69's Avatar
Well it was 50 degrees a tail wind.....couldn't have been better. Car was definitely stronger but ripped out the trans on the way up. lol I was able to get it home but once it was there it didn't have any gears. i think I took out the pump again. I checked fluid and it was showing way over full while running so the pump isn't sucking the fluid back in. Oh well that's the only thing still stock on my car. A stock PG probably isn't going to cut it. We'll tear it apart and see what's going on. Probably send the convertor in while I have it out and tightened up a couple hundred rpms and get it checked out.
At least I did it after my son got a chance to drive it. He left a happy young man.
Old Nov 30, 2013 | 08:38 PM
  #32
89ROC-Z's Avatar
Where's the vid's Nate?!
Old Nov 30, 2013 | 09:24 PM
  #33
LS1NOVA's Avatar
Eh, Im not that techy. More of a look at that **** in the mirror type of guy.
