maggie bypass valve help
Old Nov 27, 2013 | 11:24 PM
s10_ls1's Avatar
Default maggie bypass valve help
Is anyone running or know if u can run a different type of bypass valve on a Maggie I got some different fuel rails and the bypass will No longer fit on the side
Old Nov 28, 2013 | 03:27 PM
s10_ls1's Avatar
No one that's what I'm afraid of
Old Nov 28, 2013 | 04:46 PM
LS1-IROC's Avatar
Not that I'm aware of. Why not just run the maggie rails, they are nice pieces.
Old Nov 28, 2013 | 05:16 PM
N20zuki's Avatar
X2... I would assume you would max out the blowers capability to make power before maxing out the fuel rails.
Old Nov 28, 2013 | 08:25 PM
s10_ls1's Avatar
The reason for the rail swap is because I have the Nitrous express nxl direct port kit and the rails are part of the kit..
Old Nov 30, 2013 | 12:18 PM
Pocket's Avatar
The BPV is a simple butterfly valve with a vacuum actuator. Figure out how to extend the rod on the actuator and mount it anywhere
Pretty much all actuators are the same, Oem Gm, ford and magnacharger
Old Nov 30, 2013 | 03:30 PM
s10_ls1's Avatar
Thanks for the help that's what I'm in the middle of now making a template to extend the bracket for the actuator then going to cut the rod in half and extend it.. thanks again for the input
