Which is the better AR...68 or .81?
Old Dec 7, 2013 | 08:05 AM
  #61
Sarg's Avatar
1200 hp kit should be plenty for a 1000 crank car and is only $469 before shipping:
http://www.frozenboost.com/product_i...14209381f9a5a6
Old Dec 7, 2013 | 09:14 AM
  #62
Wicked69's Avatar
Originally Posted by 69-chvl
I like this idea. Heck you can also use the oil pressure circuit also for datalogable pre and post i/c #'s. Nice tip
I plan to do this once I get it running again and pull the IC
Old Dec 7, 2013 | 11:28 AM
  #63
71 chevy's Avatar
you are correct. you can use the oil pressue circuit temporarily for pre IC boost. Nice tip from you.
I buy my sensors on ebay. 0-100 psi, plug straight into the holley harness, $28 shipped.
Old Dec 7, 2013 | 12:10 PM
  #64
69-chvl's Avatar
Do you have a link? Those suckers were 1000.00/ea from Holley. I found the manufacturer of them but they were still over 95.00 direct.
Just need to know how to scale them properly.
Think these sensors could hold up on the hotside or the downpipe? That interesting also.
Old Dec 7, 2013 | 12:33 PM
  #65
toytech93's Avatar
I also would like a link to those sensors, $28 is a whole lot more reasonable.
Old Dec 7, 2013 | 01:57 PM
  #66
71 chevy's Avatar
http://www.ebay.com/itm/Pressure-transducer-or-sender-100-psi-stainless-steel-for-oil-fuel-air-water-/261260635816?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd458eea8&vxp=mtr
for the downpipe you would need to buy the autometer copper line kit to put in between. its like $14 at summit.
Old Dec 9, 2013 | 01:09 AM
  #67
quik67's Avatar
Pressure Transducer or Sender 100 PSI Stainless Steel for Oil Fuel Air Water | eBay
Thanks for the link buddy, gonna buy a couple myself.
Old Dec 9, 2013 | 10:18 AM
  #68
71 chevy's Avatar
any time
Old Dec 9, 2013 | 06:12 PM
  #69
Orr89rocz's Avatar
P trims arent done yet. Go .96-1.00 a/r. I make over a 1000 thru a stalled th400 on master power 70's .96's
New turbos are nice but i'd say housing upgrade would definately pick up
Old Dec 9, 2013 | 06:37 PM
  #70
Wicked69's Avatar
Damn that's gettin it done. I am going to just try and pull the IC first and see how it does. I ran my JY engines with no IC and just pushed them a little too hard and high compression. I am pretty sure it's holding me back. If not I will throw it back on.
Old Dec 9, 2013 | 08:13 PM
  #71
Orr89rocz's Avatar
Pressure taps before and after will give you an idea. I run the treadstone 1300 hp cooler and see 42 deg rise at 24 psi boost. I havent done backpressure readings yet but i need to for sake of data. I'm breathing out through dual 3" to bumper with 2 mufflers per bank. It has to have alittle pressure
Now i am just assuming on3 uses similar copied wheels as master power. I dont know what on3 uses so your numbers may vary
Old Dec 10, 2013 | 09:41 AM
  #72
toytech93's Avatar
Question Slightly off topic
Since someone found cheaper pressure sensors, I figured it wouldn't hurt to ask.
Would Anyone have an idea on a cheaper alternative to Holley's NTK wideband sensors ? Holley #554-100 list for $209 each.
Old Dec 10, 2013 | 10:39 AM
  #73
IMPATIENT 1's Avatar
Anyone have a cheaper alternative to a racepak etc to datalog 5-6 transducers?
Old Dec 10, 2013 | 12:08 PM
  #74
slow67's Avatar
Gingervitis Addict
Innovate logger like Hass uses.
Old Dec 10, 2013 | 12:43 PM
  #75
C'mon brother, this is the one site i dont have to read that name lmao
you know what im after boost/iats/keel hg/upper and lower intake psi/bowl psi
Old Jan 18, 2014 | 10:32 PM
  #76
00Z71's Avatar
I talked to on3.
I was thinking of running twins on a 365
The 70mm turbine is 73.5x64.5
The 76mm turbine is 74.5x65
Available A/R's on both turbos .68 , .81 , .96 , 1.0 , and 1.15
