Turbo lt1 build help.
Compressor Wheel Trim: 50
Compressor A/R: 0.66
Turbine Wheel Trim: 77
Turbine A/R: 1.05
Compressor Wheel Inducer: 68.9mm
Compressor Wheel Exducer: 98mm
Turbine Wheel Inducer: 88mm
Turbine Wheel Exducer: 77.4m
I have slp shorty headers i plan on flipping around. (hopefully these will work) Otherwise i was going to go ahead and use stock manifolds.
I plan on running right around 7psi until she pops or im going to throw some forged rods and pistons in. Whatever my budget allows for. I am new to the turbo world but i know enough to get the job done from some dsm's i've owned and months of research.
Any help or info will be great guys.
Here is what i have already/ordered
Turbo
Tail 44mm wastegate
lots of 2 1/4" mild steel piping
Appropriate flanges and couplers (on back order)argg
dual walbro fuel pump setup
aeromotive fpr
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
