Port matching headers - helps or hurts with turbo?
Let's say on a street/strip combo, with fairly mild cam and turbo on the smallish side so backpressure would be let's say 2:1.
So, is port-matching good idea?
I've kinda automatically port matched my headers to heads, but then started to doubt. I have fairly mild cam with 0* overlap at .05".
Should I open up the ports in headers again so there is a step?
I couldn't find any real testing done on this subject for now...
I'd say you'd be hard pushed to see any noticeable or measurable difference by spending the time doing it.
that would go for both the port matching or the step. Unless there was a huge mismatch in the first place.
But if you have time to kill and are inclined to do so...go for it.
I'd sooner put the effort into a better turbocharger
Ideally, the header should match the head port so a smooth transition exists. Going from head port into a larger header tube (as in a step up in cross section area when the header tube covers more than the head exhaust port itself) slows down gas velocity and changes pressure wave dynamics. You want velocity through the system although a slight step has been said to be a anti reversion dam, but if the valve events are right in the first place, there really shouldnt be much reversion. Now if header tube is smaller than port, it can be a minor flow restriction but doesnt seem to hurt as most exhaust gas comes out through the center of the port. But a turbo car doesnt seem to be as sensitive to header design like n/a setups I wouldnt worry about a minor mismatch, just get it close and enjoy.
How much of a mismatch are you looking at?
I had upto .1" mismatch in some spots. Now I matched one head perfectly and the other head I mostly matched before I've remembered about anti-reversion features of port mismatch.
stevieturbo, how can you put effort in a turbocharger? You just save money and buy it )
Exactly. Spend that time earning the money instead of doing frivolous things.
You could spend hours with port matching and achieve almost nothing. Or spend hours earning money to buy a turbo that will achieve plenty.
No no no, I'm not going to mess with port shapes or anything else, just wanted to get rid of the lip (leave not more than .05" in few spots but closer to .02" or even flush in majority of the circumreference, just for slight misalignment even with locating dowels).
