Turning it up this summer!
Old Dec 12, 2013 | 12:17 PM
ToxicWS6's Avatar
Default Turning it up this summer!
so this past spring i finished my engine and turbo build on my 2000 ws6 learned how to tune it and had a good race season for what was left of it once the car was tuned in
im currently running a 5.3L iron block stock short block, epp blower cam and 243 heads with arp head studs and ls9 head gaskets, all this putting me around 9:1cr
running t76 front mount on 12psi with 93oct, seimens 60lbs and 340lph pump
what im thinkin of doimg is taking my 2bar sd set up and going 3 bar sd and turning up the boost to ether 16-18psi, ive heard of 100% stock ls1s running 16-17 on a safe good tune so im feeling that on a lower compression engine should be fairly safe yes?
would you all feel this is pushing this engine setup or no?
do you all feel this fuel system will keep uo or will i end up needing bigger injectors?
i plan on taking my car and dynoing it at 8psi to get a base line and go from there
Old Dec 12, 2013 | 12:47 PM
SPRAYED 01's Avatar
I think you can push that kind of boost but not on that fuel. Go e85 or meth, run like 11.0 afr and call it good
Old Dec 12, 2013 | 09:01 PM
ToxicWS6's Avatar
ive been thinkin hard on going E85 caust theres a station donw the street, just have to redo fuel lines
what do you feel my limits at on 93?
Old Dec 12, 2013 | 09:49 PM
sbcgenII's Avatar
I wouldn't switch to a 3bar just to run 16psi. Only 9 to 1 compression Turn it up to 20 psi and get some meth or e85. Either going to spend more on fuel system or by a meth kit.
Old Dec 13, 2013 | 07:25 AM
RedRocketZ28's Avatar
Why would you have to redo the fuel lines to run E85? Get bigger injectors and add another pump.
Old Dec 13, 2013 | 07:28 AM
Ryans99ls1's Avatar
See sig, run E85 and youll be fine. Im going 3bar, 127lb injectors, dual 340s and turning it up to 18-20psi for next year.
Old Dec 13, 2013 | 08:39 AM
ToxicWS6's Avatar
thats actually exactly what i was going to do/run on my car if i went e85
i wouldnt need bigger fuel lines and rails to supply enough E85 for that type of horse power? and also dosnt stock stuff corrode out or does the metal hard line work ok with E85?
Old Dec 13, 2013 | 08:44 AM
I ran stock lines, rails, with a FPR to around 650 rwhp. Many have gone higher than that.
Old Dec 13, 2013 | 09:24 AM
ToxicWS6's Avatar
all on e85? and when u say "with a FPR" are u refering to using the stock one or buying an aftermarket?
Old Dec 13, 2013 | 09:49 AM
Yep, all on E85. I started out running stock lines, rails and a boost referenced fuel pressure regulator. I upgraded to -8 feed, Holley rails, 127# injectors and using the stock feed as my return. I have two pumps, one is a 255 and the other is a Racetronix 340.
Old Dec 13, 2013 | 09:53 AM
Ryans99ls1's Avatar
stock lines/rails have gone to 800+ on E85, most people do the lines cus they get fuel rails.
The stock lines are metal, they wont corrode.
Old Dec 13, 2013 | 10:27 AM
ToxicWS6's Avatar
ight cool, sounds good to me lol, should i stick with stock FPR and see how it does?
