fAST 3 bar map and mounting on Fast102
Old Dec 15, 2013 | 10:15 PM
Patsy57's Avatar
Default fAST 3 bar map and mounting on Fast102
Hey guys wondering how I should mount my new 3bar map sensor to my fast 102? Any pics etc of how you did yours would be greatly appreciated!
Thanks
Old Dec 16, 2013 | 03:57 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I've got a Fast 90, but same concept. I used a screw in barb fitting, and tapped the manifold, then attached the map sensor with a hose and clamp on each end.
You can see it in the upper left hand corner of the picture.
Old Dec 16, 2013 | 05:54 PM
Patsy57's Avatar
So what fitting did you use that you tapped into the manifold?
Any particular place you put it? Looking back any better places?
Thanks!
Old Dec 16, 2013 | 05:58 PM
UNDER PRESSURE MOD
Well, I simply opened up the existing hole that's there for the map sensor, and threaded in the barb. I used a regular hose barb that you can get at home depot. I kept it there because the plug is there, so I didn't have to extend any wiring harnesses.
Old Dec 17, 2013 | 07:15 PM
Patsy57's Avatar
[QUOTE=The Alchemist;17890838]Well, I simply opened up the existing hole that's there for the map sensor, and threaded in the barb. I used a regular hose barb that you can get at home depot. I kept it there because the plug is there, so I didn't have to extend any wiring harnesses.[/QUOTE
Is it true that its better to mount it on the back?
Old Dec 17, 2013 | 07:28 PM
UNDER PRESSURE MOD
I have no clue. It's where it was mounted before, so I kept it there.
Old Jan 4, 2014 | 04:23 PM
Patsy57's Avatar
what size fitting with what size barb did you use?
