Boost leak around injectors!
Old Dec 16, 2013 | 06:25 PM
MillsMotorvation's Avatar
Default Boost leak around injectors!
I have a Victor jr carb intake that I drilled for injectors, I had 60lb in it, and upgraded to 80lb. Now its leaking around 2 of the injectors when I ran a boost leak test. Do they sell over sized O rings? The 60s didn't leak, but 2 of these do. Should I just add glue?
Old Dec 16, 2013 | 06:42 PM
HexenLord's Avatar
Were the 80s new? You may just need new seals. Lots of places sell seal kits with pretty much any sized O-ring out there. I bought some from FIC a while back that worked great.
Old Dec 16, 2013 | 06:47 PM
oange ss's Avatar
I had the same problem switching to SD 80's. Katech sells oversize orings that will solve your problem
Old Dec 16, 2013 | 07:09 PM
IMPATIENT 1's Avatar
When u guys need orings if whatever sort dont forget your local deere dealership.their parts dept can get any i.d./o.d./thickness/material you need ,most times overnite or onhand.. had hell with a bov oring awhile back and our parts dept has awesome access to nice orings made of whatever u want.getting a oversized injector oring wld be easy from them with a old one in hand.just a thot
Old Dec 16, 2013 | 10:07 PM
Yes they are new, I thank you guys for the info. I would ask for part numbers, but I will just take one with me to John Deer, or call FIC!
Old Dec 16, 2013 | 10:48 PM
LASTLS1's Avatar
6 Second Club Moderator
Katechl, they work great!
Old Dec 16, 2013 | 10:52 PM
MontecarloDrag's Avatar
A Oring seal is measured by both its diameter and thickness. Some are metric, some are english
Go to a Parker/Gates hydraulics shop, they have a lot of different O-rings sizes.
You may need to use a slightly thicker one. Use a little oil to install them to avoid damaging the seal
Old Dec 17, 2013 | 05:17 AM
forcd ind's Avatar
I think the LS1 style used thicker gaskets than the LS3, so GM has 2 diff sizes-I might have it backwards, I know when I swapped injs. on my LS3 intake, I had to change o rings
Old Dec 17, 2013 | 06:09 PM
Thanks a lot. I called FIC they said the 80s came with the 14mm O rings,which is the thickest they had, so I will check on the parker&gates, and any other place I can find thicker ones!
Old Dec 17, 2013 | 06:22 PM
Cant seem to find them on there, got any link?
Old Dec 17, 2013 | 06:38 PM
oange ss's Avatar
OD is not the issue, 80lb SD have a slightly smaller o-ring boss requiring an o-ring with a smaller ID
call to verify
http://store.katechengines.com/fuel-...ring-p311.aspx
Old Dec 17, 2013 | 08:54 PM
wild1100's Avatar
I can vouch for the ones from katech. I'm using them on my ls6 intake with the Siemens deka 80lb injectors before the would leak bad when I did boost leak test now no issues at all.
Old Dec 17, 2013 | 09:35 PM
Tirefire's Avatar
Were you guys losing a lot of psi through the injectors??
Old Dec 18, 2013 | 05:52 AM
69-chvl's Avatar
Here's another option. You can get pretty much whatever you want.
http://www.mcmaster.com/#o-rings/=puyzob
Old Dec 18, 2013 | 01:23 PM
I went to John Deer, Kubota, and Part Stores! Finally I just told the girl to give me injector O rings for a 2007 GMC Serria with a 6.0. Looked at the lower&upper O rings, and the upper ones seem to be thicker so I installed them. Didn't do a boost leak check yet got to go to work!
Old Dec 18, 2013 | 04:46 PM
Tirefire's Avatar
So how much psi was everyone losing? Was it a significant amount?
Old Dec 19, 2013 | 02:33 PM
Ryans99ls1's Avatar
My 80s leaked when i put them in my fast rail. Took the orings from my stock injectors and rail and swapped em over to the 80s. Things have been fine ever since.
