Stall speed for street
Old Dec 26, 2013 | 10:35 AM
HRHohio's Avatar
Hate to piggyback, but since there was a TH400 comment in here, maybe this will help him too.
What stall speedfor a TH350/TH400 for street/strip?
My setup will be 273 gears on 26 in tires, looking for 600 rwhp. Is 3600 going to be too high? (will I run into issues on highway cruising if the Stall is 3600 and the motor is turning at 2500@ 70mph?)
Thnx.
Old Dec 26, 2013 | 12:09 PM
Tjabo's Avatar
Sorry, really stupid question here probably, but I'm confused by some of the comments in this thread.... Can you get a lockup converter for a TH400?
Old Dec 26, 2013 | 01:55 PM
69-chvl's Avatar
X2 - I mentioned I have a TH400 a couple of times and yet there's alot of "disk" talk. Pretty sure we have a couple of different scenerios being talked about here.
Old Dec 26, 2013 | 02:21 PM
allout06's Avatar
Pretty sure the valve body has to support lock up. i dont believe your standard th400 can have lock up unless you specifically asked for it. i may be wrong.
as far as price.. this is a good read..
https://ls1tech.com/forums/automatic...education.html
Old Dec 26, 2013 | 03:19 PM
69-chvl's Avatar
Thanks for the link - it was a nice read!
Old Dec 26, 2013 | 07:23 PM
allout06's Avatar
No Problem
Old Dec 28, 2013 | 12:18 PM
69-chvl's Avatar
My great neighbor friend just gave me a freshly rebuilt BOP th400 and a 10" ATI "Streetmaster" converter. ATI says is good for 800-1000 more stall over stock. Not sure what the stock stall is. Friend says it was around 2800rpms or so. Since its free I'm going to try it, but I dont know if this converter will like the 3.27 rear. ATI specs this conveter for 4.11+ rears. I could then get this tightened up or just go ahead and get the "right" converter.
thoughts??
Old Dec 28, 2013 | 01:37 PM
11SECSS's Avatar
I'm sure its different for a turbo vs supercharger,but I run a YANK SS4000 stall with my D1 in my 4l65E and have no complaints.
Old Dec 28, 2013 | 05:07 PM
Preston99WS6's Avatar
thoughts??
The BOP converter has a different bolt pattern than a chevy, your going to atleast have to drill the flywheel. FYI
Old Dec 28, 2013 | 05:20 PM
69-chvl's Avatar
Sure about that? The trans does have a different bolt pattern, but the converter should be the same for all th350/400's.
Old Dec 28, 2013 | 05:56 PM
Pretty sure my first ride was a 68 GTO had a 455 poncho motor in it TH-400, I ordered a stall for it and got one for a chevy, the bolt pattern on that converter was smaller, so I drilled the flywheel and ran it anyway, The input shaft is the same and so is the spacing but BOP has a wider bolt pattern by about 3/4 inch if I remember correctly This was about 8 years ago. so I had to drill new holes about 3/8 inch inside of the factory BOP holes on my pontiac flex plate. What you can do is have your converter shop weld on a pilot and adapter plate to the converter and it would be a direct bolt up then, no spacer or drilling required would be stronger than running spaced bolts and a spacer too and would probably be cheap to do around 100 dollars if I was to guess. The cameron converter in my T/A was done that way so it is now a direct bolt up. I can get a pic of it if your curious about what involved with what I am talking about.
Old Dec 29, 2013 | 08:43 AM
  #32
69-chvl's Avatar
Thanks Preston for the info. Yeah, it was off a bit and just a bit of hole enlarging got the converter bolted up to the flex. This converter had a dual bolt pattern, and both patterns were "off envenly". I thought I read this was standard practice to open a LS flywheel for a th350/400 converter.
Old Dec 29, 2013 | 10:18 AM
  #33
Mt.Dew's Avatar
Guys , Don't cheap out on converters for a turbo car. Get with a company that knows how to spec them out. You can get one for a th400 to LS flexplate, no spacers needed.
The Converter Makes or Breaks a turbo car.
Old Dec 29, 2013 | 07:34 PM
  #34
I agree but cameron built mine custom for my application at a fraction of the cost of competitors and you cant get much better than what he puts out. Besides from what I gather this converter was free so why not try it, if its loose run some John Deere hydraulic and tighten it up about 300-500 rpm, other benefits are reduced trans temps mine dropped about 30 degrees and firmer shifts as the fluid doesnt have any detergents like dextron 3.
