Stall speed for street
I just hope to avoid that loose mushy feel at part throttle that I've felt with other converters in n/a applications.
AES390, Twin Turbonetics TC66's, 229/235 .610/.627 114+6 cam, 3.90 gear, 4L80e.
95% street car.
I've used 2800 before and honestly thought it was holding me back a little. Still perfectly driveable. 3200-3400 seems to be the sweet spot for most street apps since a large portion of the setups on here focus around a ~76mm turbo or either twins or 88mm for the larger displacment motors.
As long as the stall doesn't seem obviously wrong, like a 2600 or a 4600, then what is being spec'd to you is most likely well within the ballpark of what you need.
Assume the "disks" are referring to a OD converter? I'm a Th400 guy.
Is $550 enough for a good converter? Sure. But just because its $550 and the stall you need doesn't make it a good converter..
