So many different cams these days.
What kind of DCR numbers do cam guys shoot for in a turbo engine?
what kind of cranking pressure/dynamic compression would be considered acceptable for boosted application, if you add boost into the calculator it bumps dynamic compression up to like 13:1 at just 8-10 psi from 8.5:1 with no boost..
dont mean to hijack the thread but having a lot of questions myself on cam selection. will be running E85 and a front mount so im sure there is plenty of room to work with. and as stated above there really is not much for boosted applications on dynamic compression a lot for NA though.
