Procharger Installed! Few Q's
Also installed 38 lb injectors. Couple of Q's
How loud is the whine, mine is really quiet. Not like my friends Vortech.
What is a good starting place for timing. Right now I have it set @ 15. And O2's are about .940 No KR @ WOT.
I am at the point of finally having tuning done. I would like to chime in as well as learn from your thread.
Also, my LTtrims were maxed out at 25. The first order of business was to correct this and now I have neg lt trims at 1/2 throttle like they should be.
Three questions for you...
1) Are you showing KR below 2500 rpms? I do and it gets worse with the boost being increased.
2) Did you have LT trim problems and what do yours read?
3) Should you add timing for increased performance? Move up to 18 or 19 deg if KR is not present? This is what I was told by friends (not the person doing my tuning). So you are saying less is better 15 or 16 deg.
I am learning from my tuning experience and am not an expert, hope you do not mind me asking questions & sharing thoughts on your thread.
I really want to learn more about tuning. 1. I am an A4, so once I floor it, the converter will take me over 3000 rpms. I might get up to 2* of KR, but will drop to zero. Guessing my exhaust is hitting. I do have some part throttle KR. Either cause I am bogging in gear or too much part-throttle timing. It's still stock.
2. My LT''s were +12 when I installed the 38 lbs injectors. I have been slowing scaling the IFR smaller and right now they are around zero. I'll drive some more and let them settle down
3. I started low because I am still running 11:1 heads. But from what I understand with NA, more timing = more power. With no KR of course. FI I think should be the same.
No problems on the questions, I am still learning too.
Are you using a FMU? Did the 38# injectors come with the kit? What type of fuel pump are you using and did it come with the kit?
The reason why I am asking is I show my car mostly, now after 2 yrs of having the ATI I am trying to try and get a little more HP and want to go to the track once or twice.
I had the FMU but took it off (had problems with it), I can explain if you have one. I have the stock injectors and the ATI inline pro pump that came with the kit.
I am probably going to bug you a couple more times, should I pm you? Again thanks for your time.
Right now I am running the stock pump. It's held up to 480 rwhp. But I plan on upgrading it soon.
You can post here, someones else might chime in.
I was looking to go the same route. I want the D1Sc though. Do you mind letting me know where you got yours from. I'm in Cali too so I'm looking for a good deal
Once again congrats, I wouldn't floor it until proper tuning is done
The only reason I didn't go with the D1 is the P1 is CARB legal. I got it on sale @ http://www.exoticperformanceplus.com/
I tune myself with EDIT. It gets up a moves pretty good. Right now it is safely tuned. No KR # WOT. I'll get it on the dyno and fine tune it. Gauges are going tomorrow so I can see how much boost I am running.
I wouldn't run more than 4 lbs of boost with those heads, i'm sure you plan on changing those out.
go get her tuned, you will love boost!
Make sure and use a good oil separator and a good check valve in the PCV, your compression is high so be carefull and dont get greedy
Bob at EPP is a good guy, thats where I bought my P1 from..
I am talking with Jay right now about his 6.0L heads.
Since, I am getting no KR. I should be ok for a while. And my EFI is always running.
Yes boost is fun! Not quite as a hit as N20. But knowing it is there all the time.
Thanks for the hints. I was wondering if I can run full timing at lower RPM's. I started @ 3600 /.56 to be safe.
Oil separator and check valve. No one told me about them.
Isn't the PCV valve a check valve in itself?
The pcv valve will not hold boost, thats not what its made to do. I use a viton tipped check valve from mcmaster carr (PN 7775K52 ~10.00). I am also using an AMW (sponsor on the right) catch can that almost 100% eliminated oil in my intake from the PCV. Oil in intake + boost + high compression = real bad
Can't wait to check it out !
My 30th was dropped off this morning at Don Lee's for ARP rod bolts, ARP head bolts, new oil dipstick (creased from being bent around), getting the stock exhaust put back on for a little while
, new valvesprings/valvetrain inspection, and a couple of other little things.It's running fine but a little extra insurance and a "yearly physical" is a good safety measure. 14k miles on the valvesprings that are currently in there.
It should be back in a week or so, we'll have to get together so I can check out the new FI setup !
Rob (Bad30th)
I'll check into the check valve. Is this something I can get at a local part store??
That is probably why I am only getting 2# of boost. Going to re-tighten the belt.
Rob (Bad30th)
Give me a call when you get your car back.
Tighten the belt and still only see 2# of boost. How much could I be losing through the PCV valve??
Here are the boost levels I show with the MMS Crank pulley...
410=4#
360=6#
340=8#
Give or take a little. No slipping with the MMS Crank pulley.
Do not tighten the belt to much or you will chew up the belt.
Everyone thought I was slipping because of my boost being low but the gauge was accurate and there was no slipping. Shows = 4#
Dyno & racing = 6# or 8# of boost and I will swap tunes.
True, my exhaust probably did drop the boost some. I'll get it on a dyno for the true test. But the boost starts @ 1.5 -2 when I floor it and stays there all the way to 6300 rpms
I am going to loosen the belt some, seeing it didn't help. I do have it pretty tight. I can only move it about a 1/4 in.
How tight should it be?
Guess I will order some extra pulleys and belts
