THE LIST-Top 10 STOCK BOTTOM END LSx(s)
#102
1)skinnies 8.65@167.9 JY 5.3 @2600lbs
2) Stock48-8.39@164mph-LQ4@23psi 3300lbs (Best ET)
3) ScreamingL 8.65@163.9 LY6@24 psi 3160lbs
3) Dudeman-8.6@161mph trap-LY6 @3100lbs
4) silver_82 8.55@159.5 LM7 @3250lbs
All are swap cars.
Everyone that provided a weight is listed. Also, I did not want to clog up the OP with miles of set up info like rod bolts, head gaskets, miles on motor...I am using the info people give me and set up this thread as a general reference since there was no actual list of who's at the top.
I figured if someone wanted specific question answered they could use the search function or PM the owner of the car.
#105
It's a stock 5.3 block bored to a 347, stock crank, custom cam, billet 76mm on 23 psi, on radials, and I was ATA at the time. I just went ATW and we are trying to sort the combo out now. Hopefully I will have new/better numbers soon.
#106
#107
Bored? OE pistons and Rods? I clarified the thread title in case there was confusion. This list should be only OE block/pistons/crank/rods powereded cars.
#110
Almost 3 years ago, we made 786 rwhp on a stock LS6 bottom end in V-series techs' 00 FRC. It did have AFR 205s, but it was on pump gas and would have made more if we hadn't run out of fuel. Twin precision 67s at 12 psi.
Here's a link to the thread:
https://ls1tech.com/forums/dynamomet...light=786+rwhp
#113
3) ScreamingL 8.65@163.9 LY6@24 psi 3400llbs w/ driver
#116
I think after cage im around 3300lbs now id guess.
You are right I do need to saddle up. My weak *** launches and shifting at 5800 are killing me. AKA I need a driver mod. Long way off from those guys though.
#117
#118
It was an accident. I have only made 1 "real" pass and 3 shakedown passes. I let the car drive out of the groove and short shifted when I started spinning. Still went 9.4@149
Hoping to make some more passes in a few weeks. Try out the T-Brake and a better shift RPM. Hopefully find my way into the 8s!
#119
My junk went 9.54@ 148 @ 3510lbs - LY6 17.5psi S480 turbo - swap 67 camaro, with blowthrough carb.
I know it doesnt touch the top contenders, but I'm putting it out there.
There is so much potential still in it, that it is sick, I am doing twice the work to get my stick shift combo down the track, and havent bothered increasing boost since I cant get the car to hook, lol.
EDIT: untouched 100K mile shortblock.
#120
