Turbo 6.0 nova 4l80e holley efi.
Ron , I thought about runnig mine out the front like my fairmont but I'm trying to make this thing as quiet as possiable inside the car . The fairmont isn't that loud inside I drive it everywhere but id like to see how it sounds all the way out back on my nova. I wish you lived closer Ron I'd hook you up defintly us turbo guys gotta help each other out you know. Haha!
I might end up under the car too. Was just hoping to eliminate the weight and cost of doing that right now.
I had dual 3.5" on with the big block, with 4 mufflers and tail pipes. Over 100 lbs, and it was still loud!
Yeah I never could quiet down my bbc either. Your probably doing the right thing by not running out tha back I'm probably gonna end up just dumping it. But I thought I'd give it a try with some free stainless. Lol! One thing I like about just dumping by the front tire is that there no drone at cruise speeds.
I was planing on making a y then go into two mufflers but I think I'm gonna go 4 inch all the way to the back and put a few straight through mufflers in sequence. And see how that works .
I have dual 3" pipes run out to the fuel tank with 3-chamber Flowmasters. The turbo engine is noticeably quieter than the old SBC. My Magnafuel pump is louder than the exhaust at idle and cruise. I really like having the full exhaust but I am thinking about replacing the 3-chamber mufflers with a straight through design for less back pressure. Another idea is to try adding mufflers to the wastegates since I currently just dump them to atmosphere. If they were quieter you probably could barely hear my car going down the track.
Video Link: http://www.youtube.com/watch?v=nLtZamkbHRo
#34
This is Zbrowns setup. Something similar with a 3" DP to a dump and 2" piping to the rear of the car would be perfect.
![](http://i152.photobucket.com/albums/s167/rotary1307cc/IMG_20130912_174300_756_zps1b754df4.jpg)
I ran a 3" dp to a 4" electric dump. Then through factory 2" dual exhaust with 2 OEM silencers and 2 mufflers on my lexus. It looked and sounded OEM.
http://s17.photobucket.com/user/Hybr..._2860.mp4.html
#35
Hard to get things quiet with such large piping and mufflers. IMO the trick is smaller piping and a restrictive OEM style mufflers. Run your 3-4" downpipe with a dump. Then make a T merge off that with some dinky crush bent 2" exhaust back to OEM style mufflers and it will be quiet as a kitten.
#36
This is an old image I found years ago, I think it's from Vizard about muffler designs. Not sure how accurate it is. And of course there will be various chambered designs too
![](http://image.superchevy.com/f/8934532/0505phr_exh_13_z.jpg)
As far as noise goes though, I found the straight through style actually quietened my car more than a Magnaflow chambered muffler ( I tried a pair at the rear, of exact same outer dimensions to see which were quietest. Just stuck with straight through as they were quietest. )
#37
I think honestly I'm gonna do a electric cutout. I've never wanted to use one but I think I can have the best of both worlds . I've had 4 different turbo cars over the last 10 years or so and I've had every different exhaust combo you could imagine . And it'll make it easier on me running 3 inch pipe to the back instead of 4 . But I'm gonna keep the down pipe I just made incase later I wanta go back to running 4 inch out the back.
#40
Oh yeah I love miller welders. Yeah those garage floors get cold makes it nice to lay on a nice soft rug under the car doesn't it?
