How to: injector spacing truck intake
Old Jan 6, 2014 | 01:10 PM
denmah's Avatar
Moderator
Default How to: injector spacing truck intake
https://sites.google.com/site/sloppy...torspacerhowto
had some requests for this, good to have the info in the Wiki
Old Jan 7, 2014 | 06:02 AM
HexenLord's Avatar
I used 5/8" spacers to do mine. Half inch bent the tabs a little too much for me. Got everything at Lowes, spacers bolts and washers. I have the packages in the garage, I'll get pics later with part numbers if you want form those that don't have a sears nearby.
Old Jan 7, 2014 | 07:36 AM
denmah's Avatar
Moderator
nice! it would help and i would appreciate it
Old Jan 7, 2014 | 09:39 AM
ls1_chevelle's Avatar
Im disappointed. I fully expected a story on scooping a bunch of bic pens from a local registry office, cutting them to length and using valve cover bolts to hold the rails down. lol
Old Jan 7, 2014 | 10:01 AM
denmah's Avatar
Moderator
lol
Old Jan 7, 2014 | 10:13 AM
JoeyGC5's Avatar
For the tall Siemens 60lb/hr I went and cut 3/4" plastic spacers from Ace hardware to 5/8" with no issues on my first crewcab turbo build.
Old Jan 7, 2014 | 10:40 AM
HexenLord's Avatar
When I did mine, I got the spacers washers and bolts from Lowes for less than 4 bucks. No cutting or measuring. Everything fit perfect and is rock solid.
Before that I had actually bought some 5 foot long 1/4" wide PVC tubing and was going to cut it down to size. The 5/8" spacers couldn't have been a better fit. I came across them when I was getting longer bolts.
Old Jan 7, 2014 | 12:18 PM
quik67's Avatar
I was curious about this,my truck intake (2004) came with the longer injectors, no need for spacers.
Also the fuel crossover is nickel plated , not powder coated black like most of the other ones i have seen. Maybe this was from a flex fuel engine?
Old Jan 7, 2014 | 12:41 PM
lq9s from 04+ I believe had the nickel plated crossover and single feed fuel rail(no return)
Old Jan 7, 2014 | 02:21 PM
denmah's Avatar
Moderator
yes the return less gen4 style
Old Jan 7, 2014 | 03:10 PM
HexenLord's Avatar
1 Pack of each washers and bolts.
2 Packs of spacers.
Comes out to around $4 at Lowes. Perfect fit.
Old Jan 7, 2014 | 07:42 PM
quik67's Avatar
Mine has a return.
Came off a LM7.
Old Jan 8, 2014 | 12:48 AM
Blown06's Avatar
8 Second Truck Club
Your website is awesome. Does it get a lot of traffic?
Old Jan 8, 2014 | 01:07 PM
denmah's Avatar
Moderator
you know, i never really look.
it would be hard to tell anyway i think most people are indirectly using it, i would say only a small % use the main link
the others are going right to youtube or wiki or something else off shooting from the site itself.
Old Jan 13, 2014 | 01:16 AM
Joye227's Avatar
If you went with as aftermarket rails, Would y poo u use the same length spacers?
http://www.ebay.com/itm/141121496780...84.m1423.l2649
