Twin Bullseye s256 turbos on 5.3... 850rwhp?
Old 01-11-2014, 11:44 AM
Forcefed86's Avatar
Originally Posted by vettewreck
Why does the first link say .70 AR .96 AR then when you scroll down it says you are bidding on a 0.70 A/R Compressor, 0.81 A/R Turbine??
Which one do I need??
That is the cover...
Scroll down to the bottom and look at dimensions.
Comp wheel is 91mm/61mm
Exh wheel is 74.7mm/62mm
T4 .81 A/R Turbine housing
3" Vband downpipe flange.
Old 01-11-2014, 01:55 PM
vettewreck's Avatar
About to pull the trigger on those 2!! Hopefully with a good cam, fully worked 317 heads/springs and 20lbs can get me 850 to the ground!!
Old 01-11-2014, 02:07 PM
TT427's Avatar
Originally Posted by LS1NOVA
You dont have to spend $1200 per turbo. Call Forced Inductions or look on their site. Many options in the $719-850 range. Dont go too crazy with small cubes and a manual trans though.
Probably the best money spent. I like their 61's with F1 for $719 for this build. How fast you looking to go? Why twins?
Old 01-11-2014, 04:47 PM
vettewreck's Avatar
Not looking to drag it at the track. It wont hook so its more just for bragging rights and to be a highway murderer. Twins is just for the "wow" factor. Plus I like the idea of doing cheap turbos. Break them and you can replace them. I just don't have $1400 for turbos alone where the money could be spent elsewhere.
Quick Reply: Twin Bullseye s256 turbos on 5.3... 850rwhp?
