Spark Plug Question
Old Jan 17, 2014 | 06:15 PM
kevinka's Avatar
Default Spark Plug Question
hello people,
Need someone or some people to answer a question for me please
my car is a 2002 WS6 with 5.7 LS1. running a Vortec V9 SuperCharger, that
has the aftercooler kit on it. Car is running 10 Psi of boost.
Car has Platium Plugs in it right now!
I have had people tell me that i should be running Cooper plugs and other people have been telling me to stay with the Platium plugs.
I change my plugs every spring so I dont care if i have too with the cooper plugs.
Wanna know whats not going hurt my engine with the tune i have now since the car was set up with Platium plugs?
But want the best for performance
Apprectate you taking your time to read my post.
Take Care
Old Jan 17, 2014 | 06:48 PM
Jeepplr's Avatar
I have a 2002 Chevy 2500HD with an LQ4 that has a ProCharger supercharger and inter-cooler along with Snow Performance water meth injection.
I just changed the plugs on my truck and ProCharger says that I must use copper plugs with a gap 0.032. They said normal heat range was okay or one hear range cooler would be good as well but with the water injection normal was best. The platinum plugs will "blow out" is what I was told, they will not work under hard boost and with water coming in on them.
Old Jan 17, 2014 | 07:10 PM
trans2000am's Avatar
go with a colder plug i would go with a tr6 gapped at 28
Old Jan 17, 2014 | 09:12 PM
Dynospeed's Avatar
Tr6 or even a tr7. Gapped at .030.
Old Jan 18, 2014 | 09:30 AM
93camaro_zzz's Avatar
I agree. TR6 gapped at .030. You will not need to retune anything.
Old Jan 18, 2014 | 07:17 PM
HRHohio's Avatar
What about these. Anyone running these @ 10psi boost?
http://www.ebay.com/itm/NGK-BR7EF-V-Power-Spark-Plug-/251084225431?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a75c93b97&vxp=mtr
Old Jan 18, 2014 | 07:20 PM
thats one stage colder then the tr6 at that low of a boost i wouldnt run that plug.
Old Jan 19, 2014 | 08:40 AM
samdogmx's Avatar
I ran the br7ef from 9 psi all the way up to 23 psi. that being said I plan on going to an 8 next year.
Old Jan 19, 2014 | 09:32 AM
ddnspider's Avatar
There is NO downside to running a slightly colder plug if the tune is good. Those nonprojected br7ef plugs are excellent
Old Jan 19, 2014 | 10:44 AM
HRHohio's Avatar
Thanks.... I've heard good things about them from a few others. Was thinking of switching from my TR6's to them. Wanted some feedback. At what point is it better to go to the 7's. Looks like I'm at the threshold of it being a good move. I've heard the nonprojected tips are the way to go, reduced risk of chipping the plug insulator.
Old Jan 19, 2014 | 11:13 AM
ddnspider's Avatar
Nonprojected tips are always a good idea when boost/nitrous is in play. How much power are you making? The nonprojected tip and slightly colder plug will just give you more insurance against detonation.
Old Jan 19, 2014 | 02:17 PM
Ryans99ls1's Avatar
I ran a tr6 when I first boosted the car. They were fine at 12lbs. I switched to br7s for the hell of it and they are fine. Non projected is a safer bet
Old Jan 19, 2014 | 03:58 PM
HRHohio's Avatar
Im only pushing 10 psi, and 500 rwhp at the moment, but looking to add 3-4 psi.
Old Jan 19, 2014 | 04:28 PM
MillsMotorvation's Avatar
BR7 here14- 20psi I had problems trying out different ones.
Old Jan 19, 2014 | 04:44 PM
oakley6575's Avatar
I run the non projected 7's in my set up. Currently running 11psi but plan to run 20+. I haven't seen a downside to running the colder plug at all. Starts up and idles like it did with stock plugs in it.
Old Feb 14, 2014 | 01:12 AM
kevinka's Avatar
Thank you all for all the reply's, sorry about the late response. installed the tr6,
now once I get my suspension back together off to the dyno to check everything.
Thanks again
Old Feb 14, 2014 | 02:09 PM
denmah's Avatar
Moderator
i run a NGK TR6 - 4177 gapped at 24 in all my builds, 400-700whp
pumpgas and methanol
