microsquirt
Old Jan 31, 2014 | 11:47 PM
  #41
Joye227's Avatar
Would the Innovate MTX-L work with microsquirt? Would i still gap the 4177s at 24 if i only run 18lbs of boost versus your 24?
Old Feb 1, 2014 | 07:58 AM
  #42
aknovaman's Avatar
Yes most any wideband is supported. Download the software and play with it so you can see how simple it really is to use.
Old Feb 1, 2014 | 08:28 AM
  #43
I-H8-RICE's Avatar
does the microsquirt have a bus output, just curious if it would communicate data through an OBD connector if the pins were in the correct location.. wondering because i have this neat bluetooth thing that syncs with my phone and it would be cool to monitor info with the phone.. eliminates the need for gauges
Old Feb 1, 2014 | 08:45 AM
  #44
aknovaman's Avatar
It does have can bus data lines but I am unsure if it the same as what is needed by the elm327 and torque applications. I have not tried using it that way. Best to ask Matt at diyautotune.
Old Feb 1, 2014 | 09:26 AM
  #45
I-H8-RICE's Avatar
thanks, ill ask him when i order my system in a month or two, i was just curious if anyone had used it or not.. would be a neat feature worst case ill just get a little mount built for the laptop or something for now
Old Feb 1, 2014 | 09:59 AM
  #46
Joye227's Avatar
Ok. I havent out the cae back together yet. I was just wondering cause i didnt see anyone using the mtx-l. But soon as the weather gets better, I'll start back on it. Thanks aknovaman. Oh and the 4177s gapped at 24 would be good as a default set up for boost?
Old Mar 21, 2014 | 11:16 AM
  #47
70ssclone's Avatar
The connectors that require 12v source can you have a 12v source from the cars fuse panel to a junction connector where the coils,PCM,injectors,CAS all pickup there power? Sorry if that sounds dumb this is my first real wiring attempt I'm learning as I go
Old Mar 21, 2014 | 01:46 PM
  #48
yenkomike's Avatar
yes you can but i whould use a relay to carry the load . i use a keyed power to trip a heavy relay that has a #10 wire feeding it to power up my micro fuse panel then fuse each wire as needed. works great for me.
 Michael S. Palmer
Old Mar 21, 2014 | 01:49 PM
  #49
yenkomike's Avatar
here is mine you can just see the relay up top.
Old Mar 21, 2014 | 03:58 PM
  #50
TurboMonte's Avatar
The MTX-L will work fine with the Micro. I am running one on the MS2 in my Monte Carlo and it is flawless.
Old Mar 21, 2014 | 04:27 PM
  #51
70ssclone's Avatar
Gotcha so a keyed power wire from fuse panel of car to a relay to another fuse panel that gives power to the previously mentioned 4 connections correct?
Old Mar 21, 2014 | 05:20 PM
  #52
yenkomike's Avatar
yes that way the factory fuse box doesn't have to power the micro . and you don't get low voltage to it as well. you can run a good wire from the battery or starter and use the keyed power to kick the relay on.
that's how mine is . works good.
Old Mar 22, 2014 | 08:28 AM
  #53
70ssclone's Avatar
You mean run a wire from aux fuse panel? Or the cars fuse box
Old Mar 22, 2014 | 09:10 AM
  #54
yenkomike's Avatar
I run a good power from the starter or battery then use a keyed wire from the car fuse box to activate the relay powering the micro fuse box with the power source from the battery or starter wire.
that way when you turn the key off it turns off the relay cutting power to the micro fuse box killing the engine.
