Junkyard turbo option for daily driver 5.3
Yes I don't have specs on the motor, he just told me it was on a detroit they pulled out (think the motor is good they just wanted something else.) and knew I needed a turbo so was wondering if I could use it.
Honestly your best best is to buy the denmah sloppy special from vsracing.net. It will give you all of the main components for your build and support 600hp ish no problem. They also sell injectors. You can basically be like 1200 to your door for almost everything you need.
Like all have said even a simple JY build adds up. Its the small things you dont think of. AN fittings, Braided lines, supporting parts for the trans etc
Jay
Jay
