Twin 4.5" Intercooler question
Old Jan 27, 2014 | 12:21 PM
Crazed346's Avatar
Default Twin 4.5" Intercooler question
I know this is a very stupid question, but hey where would we be if nobody asked questions?I'm just curious if any one has tried to run the Twin 4.5" Intercoolers on a TT build? I plan to run a FMIC but I am willing to try something new if it will work! I highly doubt it will but like i said before, I am just curious!
Old Jan 27, 2014 | 01:01 PM
CaliboyTA's Avatar
i like to know this also. this was my original was going with huron single turbo hotside with custom twin ati intercoolers and meth
Old Jan 27, 2014 | 01:11 PM
Crazed346's Avatar
Well I think it is possible with a single turbo but I may be wrong. I'm curious about Twin Turbos though? Maybe someone with more knowledge will chip in and help us. I have no problem going with the FMIC, but I'm just curious.
Old Jan 27, 2014 | 01:21 PM
ls1_chevelle's Avatar
Lots of twin kits utilize 2 separate intercoolers and merge at the throttle body.
Old Jan 27, 2014 | 02:32 PM
GJS440's Avatar
I'm about to sell my twin 4.5" intercooler setup if any of you are interested?, its the complete setup including the pro flo by pass valve.
Old Jan 27, 2014 | 04:10 PM
Crazed346's Avatar
So the twin 4.5 intercoolers would be the fine at 700rwhp with a PT6766 turbo hooked to each one? And if i wanted to turn it up to 1000 rwhp it would still be fine?
Old Jan 27, 2014 | 04:51 PM
underpressureWs6's Avatar
From What i understand you shouldnt run the ATI twin intercooler setup above 15#'s of boost without meth, but they are plenty good at 15#'s im making 741/748 through them at that boost level... theyre for sale btw lol
Old Jan 27, 2014 | 05:05 PM
Crazed346's Avatar
Well i do plan to run a water/meth mix kit from snow performance. What engine is your setup on? Mine will be on a 370. If they will work then I might try to go that route instead of the FMIC.
Old Jan 28, 2014 | 06:22 AM
skinnies's Avatar
I used the 3.5" ones on my rx7 and my ltd, iats were higher but power was fine. The ltd at ~3700lbs ran 140+ mph with them and my rx7 went 156 if I remember correctly. Going to a 31x12x3 did net some lower iats, but no gain in mph on the ltd.
Old Jan 28, 2014 | 09:52 AM
I run a 365ci Ls2 with water/meth
Old Jan 28, 2014 | 03:30 PM
Crazed346's Avatar
So the 4.5" ones should be fine even if I pushed them to 1k hp with water/meth injection? I don't think I mentioned this but this is going on my DD. I only plan to stay with 700 rwhp but I just want to make sure everything will be able to stand up to 1k just in case i want more, i just want to be safe the 1st time so I don't have to change anything later down the road.
