Benefits of E85 + meth?
I believe meth injection is a great way also to keep things away from detonation but I have really only heard of guys using it on pump gas.
My question is; is there any added benefit to running meth injection with E85?
To me, it would seem the E85 is already giving you all the benefits possible and that adding meth injection won't do anything. This was argued in another thread by someone claiming cooler IAT's by adding meth injection to an E85 setup. However, it would seem hard to define since meth injection is usually sprayed before the IAT sensor and would obviously cool things, but in the combustion chamber, E85 is already taking full effect.
I would love to see any technical tuning data anyone has to see if there are indeed any actual benefits to running meth injection on an E85 setup.
Setup is:
3800lb crown vic
5.3
TH400
E85
PT7675
Reason being, until someone finds a way to add an IAT sensor in the intake tract AFTER the injector, its all speculation.
About the only way I see you could get an idea would be to take your setup to the track or a dyno and some make passes logging IAT and watching the MPH (or HP if you're on the dyno)
Then put the meth on it, retune it (if needed, which it will and watch the MPH or HP if you're on the dyno.
If the numbers go up than you know the motor is making more power, which is a benefit, IMO.
Meth is around 108-110 octane.
The worst case would be that using both would result in extra octane and keep things safer?
That being said, 99% of the time my car will have water only in the a2w tank and we will 2 injectors spraying e98 pre injected to cool iats for the street/track since I hate packing ice most of the time.
IMO for the boost levels most are running, E85 alone is enough to keep out of detonation. Water injection would lower the EGT's more than methanol/ethanol. It also helps with detonation, won't mess with AFR's, and keeps everything nice and clean in the CC.
Though I guess this would assume you had to choose either or and not both. If you only are using one nozzle it will work best the closer you get it to the TB. With as cheap as nozzles are it would be most beneficial to spray a small amount all along the way using several tiny nozzles to help cool the charge. Small enough that the fluid flashes before it gets to the throttle body. Then spray the majority you want to make to the CC at the Throttle body. (Or closer)
ToolateVTEC also makes a good point that because of this it will be hard to get an answer.
I thought it was best to post this in the FI section, but really I would like to get some inputs from tuners that have direct experience with tuning with the variables.
Back almost 20 years ago I tried meth with C16 and still picked up HP. Every engine is different and cylinder heads and combustion chambers all come into play as far as boost and timing but even taking all that stuff out of it the lower IATs are going to help.
I used to use Meth and Xylene together and it worked great for a pump gas mix that was undetectable. This was long before E85 though.
During a pull my IAT drops to the teens and climbs up to the 40's at the top of 4th gear.
