How much fan is needed for boosted+ac car?
Any pics of te turbo mounted by chance? Btw thanks for all he info!
I do have a pic of the turbo in on the hotside just not one with them together.
[IMG]
[/IMG][IMG]
[/IMG] Last edited by Preston99WS6; Feb 8, 2014 at 08:06 PM.
That is pretty much exactly how I was going to mount mine lol. Down pipe out the side of the bumper. Only thing is I still have the core support in the stock location with radiator sunk inside it. You have enough room for the lower hose? Looks kinda tight lol. I was just looking through your threads, car should fly when you get her going.
I made the upper core removable but if you notice in the pics its installed so my rad is in the same location. Makes it much easier to pull the engine and trans together.
So for anyone with cooling problems that are related to poor CFM flow since ditching the original fans and shroud here is you fix and it looks almost OEM.
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG] Last edited by Preston99WS6; Feb 10, 2014 at 12:34 PM.
I wired mine to run on high speed only so I bypassed the resistor. The resistor comes as part of the fan its the plug in the bottom left corner of the pic FYI. Its only purpose is to limit starting current and operate the fans in slow speed.
I installed a 70A relay triggered from the stock ECU power wire going to the stock fans. I also put a toggle switch in here as well so I could turn it on to cool the car in the pits after a pass.
I used a 60A inline fuse.
8 gauge wire
I never measured the current draw though. But the stock alternator had no trouble keeping up with these and both 255's running.
Not my picture, this is the stock wiring.
