Turbo 6.0 powered mud truck, weird ticking noise with vid
#69
have not really updated this in a while, transmission went out and the injectors leak some water in the motor, so just been trying to rebuild everything, getting closer. Would of had the block back together but guess newer motor use different head bolts then the older blocks so going to order some and get it together
#75
was running fine with no problems, so I bought the acc harness so can use the two step, so tested first by just putting the wire on worked fine, so wired it in with my trans brake, tested it out a couple times, never rev the motor but just want to make sure tran brake still worked and motor just shut down and will not re start
#77
so found out it was the main power fuse was burnt out, so we changed it and blew as soon as we put it in, so we unplugged everything from the ecm (beside the power) and still blew the fuse as soon as we put it in, so motor guy going to call holley sometime today and see what they say
just been having nothing but back luck with this dam truck lately
#78
so talked to holley today and they said that the ecm is toast, and nothing they can do about it. only have a 90 day warranty on them. guess they said that the trans brake back fed the input wire. guess suppose to wire in a diode, which it says nothing about. so after bitching them out a little hopefully can get a good deal on a new one, suppose to be calling us back today sometime after he talks to his manager
