What size meth injection nozzles?
Also, what size metal lines? 3/16", 1/4"?
Also you don’t give enough information to give a good educated guess on nozzle size.
Are you talking about 100% meth? 50/50 mix? Washer fluid? Etc…
Is your pump gas 91 or 93?
What compression is the motor?
Redline?
What cam?
Twins on your setup aren’t going to heat up the air a ton at 10psi. If running a 50/50 mix you should be fine with a single 12gph nozzle pre TB. Double that with straight meth.
You also have to pay attention to pressure. With multiple or very large nozzles you may not see 150psi with a “150psi pump”. Also a 12pgh nozzle flows 12gph at 100psi. At 150psi it flows 14.6gph. The new pumps these days put out 250psi, 12gph nozzle would flow 18.9gph at that pressure. So you really need to know the systems pressure to calculate the nozzle sizes accurately.
Redline?
What cam?
Another fun thing to deal with is your boost pressure acting on the opposite end of the nozzle. So if you run 20lbs of boost and 150psi head pressure, the nozzle is only flowing 130psi.
Aquamist actually has a flow calculator for you to determine what size nozzles to run based on what fuel you plan to spray, and how much % of overall fueling you want.
http://howertonengineering.com/tech-...ating-jetting/
But really it makes no difference at all anyway, because virtually nobody is injecting methanol based on flow or need anyway.
You just fit a big nozzle or two and dump loads in with no flow control whatsoever.
Only the Aquamist as mentioned above generally offers an ability to control flow, unless you're doing a full standalone and using it to control flow.
