Compressor maps?
Old May 12, 2004 | 03:28 PM
MYTURBOT/A's Avatar
Question Compressor maps?
How do you figure out how much HP a turbo will support at a specific boost level? For instance i'm thinking about picking up a new T70 BB turbo with a .96 A/R and Q trim turbine. I'm trying to figure out if it will work for what i want. I know how to find the pressure ratio for a specific boost level. Like the ratio i'm looking to run is 1.8 (12psi) but how do i convert the LB/min or CFM into a max HP that it will support? FWIW i'm looking to make around 600rwhp. Thank for your assistance.
Old May 12, 2004 | 03:38 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
You need to post the Cubic inches and rev range first. Then we can go from there..
Jose
Old May 12, 2004 | 03:45 PM
LS1TECH Sponsor
BTW, I have made a map here. Good Luck....
Jose
Old May 12, 2004 | 03:52 PM
MYTURBOT/A's Avatar
Thanks. Sorry about that, It's a 346 and i'll spin it up to 6200rpm so judging by your graph you made i'll need 65 LB/min @ 12psi? I'll take a look at the comp. maps when i get home and see how it looks. Any idea how to convert LB/MIN into HP?
Old May 12, 2004 | 05:59 PM
LS1TECH Sponsor
The conversion is HP=10.86 * (lbs/min). That will give you flywheel horsepower. The 65lbs, is what the engine will consume at that rpm. I used an EV constant of about .85, and an IAT temp of 100 F. That is about normal for a nice A/A setup. If it were water to air, then we would input about 70-80 deg.
Jose
Old May 12, 2004 | 06:11 PM
MYTURBOT/A's Avatar
Well it looks like at a 1.8 press ratio the t70 will flow 65 LB/min max. You guys think that this turbo will work ok for me? Thanks again.
Old May 12, 2004 | 07:51 PM
LS1TECH Sponsor
The T76 would be much better matched for that flow rate. I have the compressor maps here. The 70 at that PR is awfully close to the choke line.
Jose
