Rack & Pinion replacement lines
There are literally thousands of types of hoses that can be used for power steering apps. Just google 'power steering hose'.
http://www.summitracing.com/search/b...e?autoview=SKU
1 x EAR-991956ERL (M18x1.50 o-ring to -6AN Male) - pressure side of rack
3 x RUS-620421 (90 degree -6 hose ends) - Both rack ports, pressure side of pump hose ends
1 x RUS-620401 (Straight -6 hose end) - Hose to pump reservoir, along with
RUS-670300 (Straight -6 to hose barb) - Braided line to rubber hose, which clamps to reservoir fitting
1 x RUS-632610 (6 foot section of power steering hose)
Make sure you get the right grade fittings and hose, it has to handle the roughly 1000psi of the power steering pump The six feet of line I ordered was plenty to route all the lines comfortably
