Does anyone make an 8 heat range RESISTOR plug with a Non-Projected Tip?
Old Mar 1, 2014 | 08:53 PM
OldGold's Avatar
Default Does anyone make an 8 heat range RESISTOR plug with a Non-Projected Tip?
I cannot run the B8EF because I must run a resistor for Microsquirt. I have tried a non-resistor and I had issues. Does anyone make an 8 heat range plug that will work in 243 heads that is non-projected tip?
Mike
Old Mar 1, 2014 | 10:00 PM
Forcefed86's Avatar
Mike
Nope... 7 is the coolest. How much boost are you running? What fuel? 7's are usually fine.
Old Mar 1, 2014 | 10:19 PM
OldGold's Avatar
Depends. Anywhere from 10-15 psi in street trim with 93 and meth. 18-22 with some race gas mixed in (C-16 or FUSE 116).
Mike
Old Mar 1, 2014 | 11:23 PM
Forcefed86's Avatar
Mike
Saw your thread. Usually have to limit the timing with hotter plugs and pump gas. No reason you should be torching plugs/heads with a 7 at those levels IMO.
Old Mar 1, 2014 | 11:30 PM
OldGold's Avatar
I'm not. I am just looking for a colder plug so that in the event I want to push it, the plug is not a limitation.
Old Mar 2, 2014 | 03:52 PM
stevieturbo's Avatar
BCR8ES...
well, it's readily available here in UK/Europe, maybe not so in the US ?
It's a gasketed, non projected cheap copper plug. I used them for a while before going to some more normal 7's
Didnt see any point in running as cold as 8's
Old Mar 2, 2014 | 04:09 PM
Forcefed86's Avatar
BCR8ES...
LS uses a tapered head plug, not gasketed. (though I've heard some people run the gasket type plug on LS heads anyway)
Old Mar 2, 2014 | 04:12 PM
I know. Ive tried various plugs in various heads. They all end up the same way, so really doesnt matter.
Besides, tapered seat plugs are very uncommon here. Almost every car here uses gasketed type plugs.
So just use what is readily available.
Old Mar 2, 2014 | 05:54 PM
dudeman's Avatar
if my memory serves me right ngk makes a 8 heat range plug but it is 13/16 hex. I couldn't use it on my mast heads. the hex was to big. I don't remember the part number off of the top of my head. I will have to go look for it again.
Old Mar 2, 2014 | 06:08 PM
dudeman's Avatar
Br8eg
Old Mar 3, 2014 | 01:09 AM
Blown06's Avatar
8 Second Truck Club
I believe you are right. Anything colder than a 7 uses a 13/16 socket, which won't fit in the head.
I wonder if one could bore the plug hole out a little and also trim a socket in the lathe enough to make it work.
Old Mar 3, 2014 | 03:47 AM
http://www.sparkplugs.co.uk/pages/da...?partno=BCR8ES
According to one site it cross references to Champion QC61YCST, not sure if that might be more available over there. Not that I particularly like Champion plugs.
Old Mar 3, 2014 | 04:50 PM
OldGold's Avatar
I ran the NGK 8 heat range non-resistor plugs. They were gasketed and still 5/8. They fit fine, they just did not get along with Microsquirt.
Old Mar 3, 2014 | 05:50 PM
dudeman's Avatar
The plug I am referring to is a resistor plug number 8 heat range but is 13/16 hex. I'm not sure if it will fit your heads.
