dual injection with e85
Old Mar 10, 2014 | 07:53 AM
STEEPSS's Avatar
Sexy!
Old Mar 10, 2014 | 09:43 AM
Forcefed86's Avatar
Originally Posted by skinnies
Here is the vic jr 16 injector setup I'm running this year on my mustang
What does it run to have the extra inj bungs added to an intake generally?
Old Mar 10, 2014 | 10:27 AM
tennerv8's Avatar
Seen that the MegaSquirt guys have been doing this for years.
Old Mar 10, 2014 | 12:39 PM
rkreigh's Avatar
a few vendors sell "injector bungs" which can be added to an alum intake by having them welded on. a bit beyond my talents!
the Vic Jr looks ultra sexy and would flow a ton but it's likely to be too tall to fit under the c5 vette hood.
I have a nice halltech stinger hood which I don't want to cut up so I'm looking at a fab intake or modding an alum "ls6 style" alum intake like the BBK above
thanks everyone for the feedback, keep it coming!
Old Mar 14, 2014 | 06:18 AM
rkreigh's Avatar
I spoke to a reputable tuner and he gave me some solid advice.
just use the 127 injectors, a big A@@ pump, alchy injection controlled by the haltech and be done with it. tuning with the dual fuel tables and two sets of injectors is a bit complicated and just not needed. kinda fits my budget too.
the scarey part is the fuel system upgrade cost!! buy hey, skimping on the fuel system is the mistake the prior tuner made with this car and one I'll not repeat.
still going to try an E85 tune as I think it's going to help me out, and keep the meth injection for insurance and cooling the IATs
now I'm more focused on twin nozzles or direct port alchy
I like the concept of direct port as I can "stagger jet" the alchy nozzles and tune with the EGTs to even out the EGTs for the "rich and lean cyl"
the haltech also allows the individual cyl tuning too on the fuel injectors so this should really be interesting.
I can see a day in the future where we install 8 wide bands and have the AF ratios adjusted dynamically for each cyll with auto tune.
expensive, but worth it!
Old Mar 14, 2014 | 07:36 AM
Smallblockguy's Avatar
Makes a custom carb price look CHEEEAAAP!
Old Mar 14, 2014 | 07:37 AM
I have 7k into a megasquirt system!
Old Mar 14, 2014 | 11:13 AM
turboventura's Avatar
I have a 4150 flanged intake and have thought about pump gas through the fuel injectors and a nitrous plate with only fuel hooked up and a seperate tank with e85 or e98. E85 is accessible locally but a pain always mapping out where your going and calling stations to make sure they have e85 and if I ever want to do drag week or something not a good option.
Old Mar 14, 2014 | 11:34 AM
That set up was my first thought. Use 4 850lb mark Mickie's injectors with the an6 ends, just pipe thread tap a carb spacer, no rails needed.
Old Mar 19, 2014 | 05:51 AM
rkreigh's Avatar
not familiar with mark mickie's injectors I wonder if they could be tapped and threaded into the nylon intake
is their any way to "plastic weld" some bungs on the nylon composite factory intake? they could be fabbed up from the right tubing material if this could be strong enough.
also thought of doing additional injectors welded in the intake pipe before the throttle body but I'm concerned about fuel distirbution problems
Old Mar 19, 2014 | 11:46 AM
skinnies's Avatar
Not a safe way to add injectors to the plastic intakes.
We spray in the charge pipe and have been fine spraying two 120lb injectors full tilt.
