LT1 Radiator
Old Mar 4, 2014 | 03:31 PM
SwampWS6's Avatar
Default LT1 Radiator
Anybody here with a LT1 front mount turbo with a vertical radiator? My turbo will sit right above the balancer and right below the water pump. What are you doing for a vertical radiator? Measurements, specs, P/N?
I called griffin for a custom radiator and they are talking about minimum $500. I have no problem spending the money but if I could spend a couple hundred less and get the same performance out of it I would be happier. Please help!
Old Mar 4, 2014 | 06:10 PM
Shownomercy's Avatar
Man-Crush Warning
Search for the vertical radiator thread, read, win.
Old Mar 4, 2014 | 07:22 PM
Gunters96lt1's Avatar
^^^this!!
didn't I show you how I did mine?
Old Mar 4, 2014 | 09:53 PM
SwampWS6's Avatar
Originally Posted by Gunters96lt1
^^^this!!
What are your specs again?
Old Mar 5, 2014 | 12:25 PM
Ill double check when i get home, but im pretty sure this is what i got.
GRI-1-25241-X Radiator, Universal, Crossflow, Aluminum, 27.5 in. Wide, 15.5 in. High, 3.0 in. Thick
Heres the thread
https://ls1tech.com/forums/forced-in...le-here-2.html
Old Mar 5, 2014 | 06:12 PM
SwampWS6's Avatar
I think I will just go ahead and purchase the rad an make my cuts. What size fans are you guyz running? Pushers, Pullers? Would my stock fans be sufficient enough for cooling?
Old Mar 5, 2014 | 06:44 PM
Man-Crush Warning
Two of these in front of the radiator
http://www.summitracing.com/parts/der-16925
Never had a over heat issue.
Old Mar 5, 2014 | 07:20 PM
SwampWS6's Avatar
Damn............Could I just use 1 big fan?
Old Mar 5, 2014 | 07:24 PM
Man-Crush Warning
You could just overheat.
Old Mar 5, 2014 | 07:30 PM
SwampWS6's Avatar
Dammit SNM..................
