The other "GT45" Ebay turbo (80mm)
Sure it would. I believe matt (denmah) made 700+whp with a 5.3 using that turbo.
My question would be… is it worth it to spend $525 on a china 88/83 when you can get a S475 for $625. I’d like to know if this turbo could hold its own against the Cast S475. My guess is the S475 would outperform it.
How much difference power wise would be between the T4 version thats been posted and the T6 version- for the same price?
http://www.ebay.com/itm/CXRacing-GT4...pVraDZ&vxp=mtr
The 88mm compressor size looked pretty similar in size to the S475. The hot side is quite a bit smaller. I don't remember which fairmont it was or I'd throw up a link.
Think they are talking about the 88/83 turbo now. The 88/83 isn't available with a t6 housing. The T6 unit posted has a much smaller exh. and compressor wheel as well.
So between the one that tonypaul posted in the ebay link and the 88/83 turbo, which one is capable of making more power? Also, which one would work better for a M6 car? I would assume the bigger exhaust and compressor wheel would mean it is capable of making more power, but it appears the 80mm turbo in the ebay link is ball bearing and I don't think the 88/83 is.
http://www.vsracing.net/catalog/prod...0cf9382a194d81
The picture in that listing is of a T4 flanged turbo.
I'd bet if you order than thing-it comes with a T4 flange and JimmyWong just had one too many saki bombs when he listed that one.
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Has anyone has the "88mm" turbo in their hands yet? As I said almost 2 years ago, I am still yet to see one. And if someone actually had a 88mm turbo, has anyome made close to 1000whp or trapped above 150mph with one?
