red race valve?
Old Mar 16, 2014 | 12:39 AM
210guy's Avatar
Default red race valve?
Hey I'm new to forced induction and was wondering if I'm able to run the red rave valve with only 7psi. I know on brutespeeds website recommends it for 14psi+ but will it not work with under 14psi?
Thanks in advanced for the help
Old Mar 16, 2014 | 07:04 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
It'll work, but it's not neccesary. I ran the regular proflo valve up until last year when I upped the boost from 14psi. Above 14psi, the proflo starts to bleed off boost and doesn't flow enough to regulate surge.
Old Mar 16, 2014 | 09:08 AM
stealth355tpi's Avatar
I'm running one on 8psi. I wanted to build my system so when I went bigger everything needed was there already.
Old Mar 16, 2014 | 09:48 AM
210guy's Avatar
Oh Ok gotcha, cause I had already bought the fmic setup with it so I thought I wasn't gonna be able to use it lol, thanks man
Old Mar 16, 2014 | 09:49 AM
210guy's Avatar
Ya that's what I figured I should do too
Old Mar 16, 2014 | 10:40 AM
conan's Avatar
I also did the same, I spent the $$$ up front and got the big red bypass so I didn't have to upgrade in the future.
Old Mar 16, 2014 | 10:46 AM
fengstang's Avatar
I had the proflow with my d1 and im running 7lbs but ended up getting it anyway.
it sounds like sex.
Old Mar 16, 2014 | 11:53 AM
210guy's Avatar
Oh ya another thing I was wondering, what size vacuum line should I run from the valve and for the gauge?
Old Mar 16, 2014 | 12:47 PM
I'm pretty sure the race valve comes with its own hard line to hook it up. Do you plan on getting the open or closed valve? The open is pretty loud but sounds good, people know your there haha
Old Mar 16, 2014 | 01:02 PM
210guy's Avatar
Ya but I got it used and didn't see any vacuum line
Old Mar 16, 2014 | 01:16 PM
210guy's Avatar
Here's the valve with fitting
Old Mar 16, 2014 | 01:24 PM
Ask Bob from brute speed, he'll be able to tell u what size it is or sell you what you need. He helped me out with a lot of questions when I was piecing my kit together.
Old Mar 16, 2014 | 01:28 PM
210guy's Avatar
Ya he's been helping me as well lol ill give him a call
Thanks for the help man
Old Mar 16, 2014 | 03:43 PM
stevieturbo's Avatar
Yes it's fine to use, and it comes supplied with a pneumatic push fitting for 1/4" OD nylon tubing
Old Mar 16, 2014 | 04:35 PM
210guy's Avatar
Thumbs up
alright cool, thanks for the info stevie
Old Mar 16, 2014 | 04:38 PM
Although it's just screwed into an 1/8" NPT port in the top of the valve, so you cold screw anything you wanted into it.
But the pneumatic push fit stuff is handy
Old Mar 16, 2014 | 06:21 PM
210guy's Avatar
Talking
awesome all i need is 1/4 nylon tubing then
