poor mans 6 bolt block
I would love to run the 6 bolt heads with a boosted motor but the price of the RHS and other aftermarket blocks with the many expensive parts makes me want to come up with a more affordable solution.
the other "more elaborate" idea would be to machine a steel "deck plate" that that has the extra "ears" machined, and use a set of longer liners in the block and the head bolts to hold it down. again, this is similar to the superdeck technology so not a new idea.
guess the answer might be "write a big check to superdeck" but I'm looking for alternatives.
prefer a 6 bolt aluminum block to keep the balance on the c5 z06 intact.
ERL has the nice technology, just looking to graft on the additional 2 mounting pads for the cyl head bolts and stay with a factory sleeve at a reasonable cost
after seeing the guy cut up LS blocks to make a V12 this should be a snap!
anyone interested?
By the time you've fucked about doing that, you could have just bought a 6 bolt block in the first place, which will ultimately be better than any welded part.
The question is...do you really need it ?
A cheaper alternative would simply be CA625 studs or upgrading to 1/2 studs.
The closer you push the limits of the fuel and compression towards detonation...that is where the risks mainly lie.
If you ran 8:1 I've no doubt you could easily run 30psi boost all day long to make the power and do it very safely.
If you run 10:1, you might do it on 20psi, but you could easily be on the ragged edge of risk.
So it's a combination of factors. Boost in itself isnt the killer.
Makes sense, I went with 9.1:1 on my motor. I should be able to cram quite a bit of boost down it at that CR
any benefit to billet main caps? I probably won't go much beyond 6500-7k rpms so I'm hoping the stock caps are plenty strong enough.
I will be running e85 on a conservative tune to stay far away from detonation.
I'll happily sacrifice a few ponies for durability as I drive the car often and occassionally on long trips (which is why the flex fuel sensor is so critical to run pump gas on low boost for just croozin around and e85 when set on kill)
the "feasibility" is what I was looking for and it goes a long way towards explaining why ERL superdeck blocks are expensive (not saying that it's not a fair price, they do some pretty extensive mods)
good tip about the "block webbing" for better liner support that's a key advantage to the superdeck block.
I'm trying to "salvage" my LS6 block and make it live as I'm hesitant to run the iron block in the vette and 1000 hp will be more than enough for me for now
but I do have a spare 4.8 iron block lying around that I was thinking about this kind experimentation. I know welding cast iron is pretty tricky, so I considered a "wide block" approach to adding the block ear which would have enough material to use 4 small cross bolts to hold the "ear" onto the side of the block and allow enough room for a stud to for the additional 2 head bolts.
sounds like the consensus is "save your money and buy the block done" or set a more reasonable and save 1,000 hp goal.
thanks for indulging my engineering ideas.
But if going to the effort of pinning....will the billets really cost that much more ? $400 + line bore cost ?
Isnt a huge amount really, plus it's a little extra strength
