Wiring up Eboost2 boost controller
Old Mar 22, 2014 | 03:52 PM
dmaxvaz's Avatar
Default Wiring up Eboost2 boost controller
i was wiring up my eboost2 boost controller, and was wondering if i needed to wire the yellow (tach signal) wire from the controller to the ground on a ign coil? is it mandatory, or can i run it without the tach signal? or what's the purpose for it anyways?
Old Mar 22, 2014 | 05:50 PM
Shownomercy's Avatar
Man-Crush Warning
Its so you can read the rpm of the motor, shift light, and for boost stability at high rpm if you have a falling off issue.
Old Mar 22, 2014 | 05:54 PM
allout06's Avatar
its used for boost by rpm too. i didnt hook mine up. it says right in the instructions that its optional
Old Mar 22, 2014 | 06:09 PM
Slow94Formula's Avatar
I have mine hooked up. If I hadn't known where the tach signal wire was under the dash I would have just left it unhooked probably. I look at it every once in a while to remind myself how far off the stock tach is as well as looking at the peak RPM sometimes.
Old Mar 22, 2014 | 06:16 PM
dmaxvaz's Avatar
i would need this signal if i wanted it to spool faster in the lower rpms? my manual boost controller would spool slower at a setting of 11 psi, and would spool faster when i set it at 17psi.
Old Mar 22, 2014 | 06:28 PM
stevieturbo's Avatar
No you would not need a tach signal to make it spool quicker.
Old Mar 22, 2014 | 07:03 PM
dmaxvaz's Avatar
thanks guys for the input.
Old Mar 22, 2014 | 07:05 PM
06cobaltSS's Avatar
no changing the gate pressure setting would effect spool.
