Electronic boost controller
Old Mar 24, 2014 | 01:08 PM
hillbillyhotrodz's Avatar
Default Electronic boost controller
What's the best bang for your buck with 3 stages of boost settings and user friendly .
I looked on ebay and there's a lot there to pick from I just don't know enough about them to buy one so I'm asking for some help with this I have 2 to 350.00 to spend .
Let me know what you guy's are using and like
Thanks Mike
Old Mar 24, 2014 | 01:22 PM
denmah's Avatar
Moderator
Amazon.com: AEM 30-4350 Tru-Boost Controller Gauge: Automotive Amazon.com: AEM 30-4350 Tru-Boost Controller Gauge: Automotive
3 settings
wastegate
A
and B settings
flip switch wire for scramble boost, alarm settings, user configurarable
peak recall etc etc
live vac and boost display
Old Mar 24, 2014 | 01:42 PM
3 settings
wastegate
A
and B settings
peak recall etc etc
Can you have 3 stages and if you only want to use one stage for driving around is it possible and then if you need more can you get it on the fly and how hard is it to set up and use.
Thanks for your post
Old Mar 24, 2014 | 01:57 PM
denmah's Avatar
Moderator
you have to hit the first button and hold for like 1.5/2 sec to switch boost levels.
or you wire in the scramble boost wire and it wil lgoto the "scramble" setting
say you drive on wastegate 10psi
go to the track and hit B wich is 18psi launch and when you hit half track or a microswitch on your shifter it can goto the "scramble" setting of 28psi for high gear
Old Mar 24, 2014 | 04:51 PM
Superman09's Avatar
LS1Tech Sponsor
Eboost-Street is very easy to set-up and operate. Very affordable as well, however it only holds 2 settings. If any interest, shoot me a PM for the very best pricing!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Mar 24, 2014 | 06:32 PM
BullF-16's Avatar
Boost Leash FTW!!!!
Old Mar 24, 2014 | 09:10 PM
SMOKNSS's Avatar
Originally Posted by BullF-16
Boost Leash FTW!!!!
X2
Old Mar 24, 2014 | 09:23 PM
MUSTANGBRKR02's Avatar
Boost Leash FTW!!!!
Just ordered mine but the OP is working on a tight budget.
Old Mar 24, 2014 | 11:09 PM
stangtrader's Avatar
Originally Posted by 01Z28Camaro
Making your own is the way to go. Cheap an you can program it to add boost instantly in a race. Start each race on say 10 psi an tap button on shifter to go up a psi max boost at a time.
Id like to see more info on this.ive tried searching on google for a how to on the adrunio pwm controller but not finding useful information
Old Mar 24, 2014 | 11:47 PM
willizm's Avatar
I have an aem truboost and it's not bad. Basically you have 3 preset boost levels. 1 spring pressure and 2 at set duty cycle for higher boost. I drive around with it disabled most of the time and bump it up when I want more boost. I'll probably go to a boost and pulse leash combo.
Old Mar 24, 2014 | 11:48 PM
redss82's Avatar
if you turn it off it will go to spring pressure so there is your third haha
