Dominator fuel pressure question
Old Mar 25, 2014 | 08:05 PM
oscs's Avatar
Default Dominator fuel pressure question
What are you guys doing to communicate the fuel pressure to the ecu? I see the sensor you can buy for $115 and was curious what you guys are using. Is there a cheaper option that doesn't suck? Does this use up a output function or is it built into the harness
Old Mar 25, 2014 | 08:44 PM
408GT's Avatar
It's built into the harness. In the engine settings table you tell the ecu what your fuel pressure is, and what pressure the injectors run at. If you're going to run a sensor I'd just bite the bullet and buy the holley.
Old Mar 25, 2014 | 09:26 PM
lidoautogroup's Avatar
Also in the same boat with the Holley EFI Hp, so I am assuming using the FP sensor is not mandatory?
Old Mar 25, 2014 | 09:46 PM
oscs's Avatar
I would like to run a sensor for insurance purposes. Thanks for the info
Old Mar 25, 2014 | 10:01 PM
oscs's Avatar
Originally Posted by lidoautogroup
Also in the same boat with the Holley EFI Hp, so I am assuming using the FPR sensor is not mandatory?
It appears that way but it makes no sense to me to spend all that money on a motor etc. and not take the appropriate steps to protect it.
Old Mar 25, 2014 | 11:42 PM
Blown06's Avatar
8 Second Truck Club
I've used both a transducer from Holley and one from Autometer and they both worked fine. Also I currently have the signal split between the Dominator box and the Autometer FP gauge.
I have an extra Autometer transducer I'll sell to you so that you can save some money. PM me if you are interested.
Old Mar 26, 2014 | 05:40 AM
JAX04's Avatar
I use the autometer once as Blown06 stated. works great for me.
Old Mar 26, 2014 | 08:06 AM
oscs's Avatar
Thanks guys I'm glad to hear you can run one off of the aftermarket FPR and the split signal idea is money.
Blown06 you have a PM
Old Mar 26, 2014 | 09:14 AM
STEEPSS's Avatar
FWIW, those transducers can be had for around $75 if you find a holley vendor to hook you up
Old Mar 26, 2014 | 09:32 AM
JAX04's Avatar
I just wanted to say, that you two with the Z cars suck ***. Beautiful cars.
Old Mar 26, 2014 | 01:36 PM
oscs's Avatar
It isn't all its cracked up to be But thank you I love my Z
Old Mar 27, 2014 | 06:02 AM
STEEPSS's Avatar
What he said.
Old Mar 27, 2014 | 08:47 AM
toytech93's Avatar
I was told by another member here that this ebay sender works with Holley's EFI.
http://www.ebay.com/itm/Pressure-transducer-sender-100-psi-stainless-steel-oil-fuel-air-water-/261260635816?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3cd458eea8
I bought 2 of them, but I have not tested them yet. My dominator setup will be installed hopefully in 2-3 weeks.
Old Mar 27, 2014 | 09:51 AM
oscs's Avatar
Pressure Transducer or Sender 100 PSI Stainless Steel for Oil Fuel Air Water | eBay
now if I can find a fuel pressure guage without a sender ill be in business
