On3 turbo, 5.3 track results
Restricted User
It's a fel pro oil pan gasket I believe.
#34
[QUOTE=ujslost2;18186344]We don't have but one 1/4 mike track around and it's a long drive. Which sucks. But I just sold the on3 76 and put a vsracing gt45 80mm on the car. Hopefully be back at the track soon.
Did you have to modify the t4 flange to fit the turbo?
I ordered the same turbo and was told I might have modify
as the turbo flange is not a t4 but similar. I really don't want
to hack up my kit.
Pictures will be great.
to hack up my kit.
#36
[QUOTE=a-low;18186545] Yes the gt45 80mm uses a t4i flange. It fits good on my huron speed kit, but I had to slot the holes on the flange a little bit.
Pics and videos to come.
to hack up my kit.
to hack up my kit.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#38
Youll love that turbo for the money. I had the cheap $250 Ebay gt45 and finally blew it up after two seasons at 16 psi so i got the 80mm gt45 and at the same boost level and a really bad 60' due to mt converter being to tight I picked up almost a half second in the 1/4
#39
Setup is
Stock 5.3
Stock 862 heads
216/221 camshaft
Huron speed turbo kit
On3 76mm
Th400
E85
Full weight car with only a pa racing k member.
This run was made on 19psi.
6.40@108
Should be good for a high 9 in the 1/4 I hope. Car is a blast and fun to drive! My best 60ft is a 1.38. If I can get the 60ft back to that, should go a 6.30.
On3 76 6.40@108 on Vimeo
Stock 5.3
Stock 862 heads
216/221 camshaft
On3 76mm
Th400
E85
6.40@108
what year model 5.3 you have?
I'm doing a 02 5.3 with twin on3 70mm with .68ar
