will a d-1 make 700+rwhp on an a4?
tell me what you guys think...
What do u mean u picked up 4psi with the FMIC? Same pulley as before? I thought a larger IC would cost u some boost, not gain boost.
NO NO man....... like i said....... you are craming tons of boost ino the small stock intercoolers and only so much can flow thru there and after that it starts to back up...... kinda like a clogged drain. If the blower was producing 18psi, but the intercoolers were restricting it and not letting air flow thru it then you will se a boost drop. If the intercooler can flow that much more you will still get a boost drop from the blower side of the intercooler, but you should see a rise on the intake side after the intercooler... it makes since...... you can only force so much air thru something before you need a bigger hole......
