how can i get my turbo to spool faster?
Like others said, assuming tune is remotely close, there must be a hotside leak or the WG is cracking open. Def way overkill on the 3", that is worth a few 100 rpm. Just to give you an idea, we have a lower comp ratio 5.3 with a gt4788 on it and we see 5psi at 3400 with a 2" cross over. With a 6.0L you should be in this same area if not lower.
Good luck.
Good luck.
No hotside leaks that i see or hear. I dont have a boost controller. Just running of my tial 44mm wastegate for now...would a regular ball n spring mbc help keep the wastegate shut? Or is there a specific type i should look for?
#33
your merge is way to big! i am running a 5.3 with ported and milled 317's, 224/224 602/602 115+4 turbo cam, and a tc78 with a .96 ar, BUT i have 2.25" crossover from the manifolds to a 2.5" merge up to the flange. i get full boost around 2900-3000, running 12psi right now, made 700
Also, 3" is pretty small for the exhaust, especially for a 6.0 i would think. i custom ordered mine with a 3.5 v band , and i have 3.5" all the way to the rear axle with a cutout and a bullet muffler.
#34
Your Hot side pipes are on the big side at 3", but your exhaust isn't helping you either, single 3" is on the small side and chambered mufflers are way too restrictive for a turbo car.
Pull the mufler and replace it with a straight thru type and i'll bet you'll see a big difference.
I would do that, and tweek the tune before jumping into rebuilding the cross over pipes.
