help! manifold gasket
Old Apr 15, 2014 | 04:11 PM
ToxicWS6's Avatar
Default help! manifold gasket
so im running a front mount turbo kit using the "truck" manifolds flipped forward, other day i blew out my driver side manifold to pipe gasket (trucks passenger side) i CAN NOT find this gasket anywhere, ive gone to advance, napas and pep boys and had them look up silverado 1500s 2500s (thought these where 6.0L manifolds) escalades and nothing comes up, only thing i get is the driver side flange gasket which is shaped diff or i get the donut/ring gasket.
what should i look up to get the proper gasket for this?
cant reliably find it on google ether get pics of it here and there but
Old Apr 15, 2014 | 06:27 PM
jrpimp00's Avatar
I dont run any gaskets on my hotside. I ensure the flanges are flat and run a small bead of copper rtv;
Old Apr 15, 2014 | 06:30 PM
stevieturbo's Avatar
If the part is on original GM vehicles, check the dealer for the part. They will list it.
Or if it is two flat flange faces, as above. Clean em up and some copper silicone.
Old Apr 15, 2014 | 08:08 PM
ToxicWS6's Avatar
they are two flat faces, ill clean them up real good and try that copper RTV, only other thing was to cut my own gasket and copper seal spray it and hope that works,
thanks guys!
Old Apr 15, 2014 | 08:14 PM
1969x11's Avatar
post a pic of the one you blew out.
Old Apr 15, 2014 | 08:42 PM
ToxicWS6's Avatar
ight lol h/o its pretty bad imo
Old Apr 15, 2014 | 08:43 PM
ToxicWS6's Avatar
Old Apr 15, 2014 | 10:14 PM
Sleeperls's Avatar
Get them clean and rtv. Do you have a brace somewhere that isnt let them sit flush?
Old Apr 16, 2014 | 06:05 AM
ToxicWS6's Avatar
nah no brace or anything, the wonderful turbo kit it happens to be though (one thing i didnt do my self i should of) wasnt the best fit so ill have to check that, but this side seemed pretty good, its held up good till i was playing with the new 2step alot that day so kinda blaiming it but lol
Old Apr 17, 2014 | 03:26 PM
Berz28's Avatar
I also just use copper RTV.
Old Apr 17, 2014 | 03:55 PM
geoff17's Avatar
CBR performance sells them in MLS.
Old Apr 17, 2014 | 05:39 PM
ToxicWS6's Avatar
/\ ill have to check that out
i used a gasket that was close and cut the bolt holes to fit, then copper rtv both sides
