Fuel pressure regulator goes on supply or return?
Old Apr 22, 2014 | 11:09 PM
703 CAMAROSS's Avatar
Ok one last question. Where does the filter go? Supply side before the rails, return side before the regulator but after the rails, or after the regulator? Or does it not matter?
Old Apr 22, 2014 | 11:52 PM
95bowtie's Avatar
Depends what pump your using.
If external pump or pumps your gonma want to put a 100 micron filter before the pump to keep any possible garbage from getting in the pump and damaging it or clogging it. 100 micron filter is basically a screen to catch big stuff.
After the pump your going to want a 10 micron so that you can catch everything possible that you can cause after that it will end up clogging the injectors.
If your using intank pumps then I would assume somewhere along the feed line to the motor before the rails your gonna want to put a 10 micron or somewhere around that rating filter in there.
Pre filter on intank setups is usually in the form of a sock on the bottom of the pump to keep and possible junk from being sucked up.
Old Apr 23, 2014 | 01:01 AM
oscs's Avatar
Originally Posted by Sarg
Mine has a -10 feed with a Y going into -8 fittings in each rail, then two seperate return lines coming out of the rail and into the regulator. I have heard is is important to try to make sure both of the lines coming out of the rail are equal length. Not sure how true this is, but I did it anyways, haha. From the regulator I have a single -10 going back to the tank.
I used the larger line due to using E85. I have had bad experiences using too small of a return on E85 and it becoming a restriction when using very large pumps. Actually had a car that at idle would not go lower than 55 psi fuel pressure, but then as the motor started actually using fuel it would drop down to 45psi before climbing back up with boost. Until I figured out what was happening I was having a HELL of a time tuning the car, lol.
Did some poking around the engine tonight (car is in the middle of a build) I decided to switch up my setup and go with the typical setup (crossover) I like the way you have it run but i just don't have the room on the front side of the motor.
Old Apr 23, 2014 | 01:03 AM
oscs's Avatar
I would say 30 micron would be plenty. Especially if E85 is ever going to be used
Old Apr 23, 2014 | 01:59 AM
stevieturbo's Avatar
The main purpose of the filter is to protect the injectors.
Place it accordingly
Old Apr 23, 2014 | 07:16 AM
Sarg's Avatar
I use a 10 on e85.
Old Apr 23, 2014 | 07:32 AM
Ok thanks. I'm using dual 340lph in tank pumps. So il place it along the feed line. Thanks.
Old Apr 23, 2014 | 08:33 AM
oscs's Avatar
I use a 10 on e85.
how long are you filters lasting you? SS mesh or paper? What kind of flow are you putting through them? I've seen a few 10's get what looks like a bunch of white hairs that clog the filter pretty quickly.
Old Apr 23, 2014 | 08:44 AM
95bowtie's Avatar
Can't answer for him but I will say every manufacturer states absolutely do not use a paper filter with ethanol/alcohol/meth use stainless only.
I too use a 10 micron post pump, my injectors got gummed up and a few stopped flowing anything all together from the corn....sent them to fuel injector connection and he fixes them up. He said the only way to keeo it from getting that bad is to send them in twice a year to get cleaned.
Old Apr 23, 2014 | 08:45 AM
Sarg's Avatar
I used the one on my wrx for 3 years on e85. It got clogged quickly at first from varnish, but after that change it was good. I believe the Ss is the 100 micron and the 10 is cellulose maybe? I would rather have "white hairs" trapped in my filter than my $1000 injectors!
Old Apr 23, 2014 | 09:04 AM
oscs's Avatar
thanks guys
Old Apr 23, 2014 | 11:46 AM
  #32
RonSSNova's Avatar
I'm using a spin on diesel paper filter before the pump. It looks just like a spin on oil filter.
I have small screens in the injector hats from ID.
Thinking I ought to have a peek at those filters and see if I'm getting any degradation of my paper filter.
This is my first experience with E85.
Good info, thanks.
Ron
Old Apr 24, 2014 | 12:18 AM
  #33
95bowtie's Avatar
I have a 10 micron in stainless. Like I said if the paper filter says it's not compatible I wouldn't try your luck with your motor.
Old Apr 24, 2014 | 02:39 AM
  #34
CameronVic's Avatar
If you are looking at the regulator The line on the left is -10 feed the line on the right is -10 feed as well, it hits the Y block and splits to (2) -8 lines. Those lines are fed to each rail constantly maintaining your desired FP. The line on the bottom of the regulator is -8 return and goes strait to the fuel tank.
This is exactly how I plan on reconfiguring mine. You sure aren't gonna run out of fuel anytime soon! I have a -8 feed y to two -6. Made about 750 to te tires on e85 and had no signs of running out!
Old Apr 24, 2014 | 02:46 AM
  #35
CameronVic's Avatar
And I'm no engineer, but I just can't see the way oscs had/has is (the way I'm switching to) being a problem. This is why, I believe the pressure everywhere in the entire system will be the same. Ex: the pressure right after the pump and at the very end of the dead headed rails. Just like pressure inside of an air compressor is equal everywhere. And saying you're going to run out of fuel with it one way vs another also makes no sense. The orientation of the lines does not make a pump flow more volume. Just my observation.
Old Apr 24, 2014 | 03:29 AM
  #36
He has effectively re-created a late model OEM setup. ie dead end rails with a regulator closer to the supply source.
The only real difference is the length of pipework involved between regulator and rails etc.
Now in theory if fuel consumed by the injectors exceeded the flow ability of the tee piece and lines that feed the rails, pressure in the rails could start dropping, but pressure on the feed side of this tee might still appear fine.
It isnt very likely to happen if pipe sizes are adequate, but it is still a less desirable way to configure it that placing the regulator after the rails.
Really given the amount of pipes already in the engine bay, I can see no positives to configuring it the way he has.
It would be just as easy and maybe less pipework to place the regulator in the most favourable location..ie after the injectors.
Old Apr 24, 2014 | 06:38 AM
  #37
Sarg's Avatar
Both my filters were alcohol compatible. I just do not remember the materials.
Old Apr 24, 2014 | 08:06 AM
  #38
rotary1307cc's Avatar
The car in the pic better plan on doing it regardless
Old Apr 24, 2014 | 12:00 PM
  #39
CameronVic's Avatar
Which people have gone incredibly fast, and made tons of power safely with.
You keep saying less than desirable. What does that mean? could you show me an example of where the only reason a car blew up was because the regulator was done pre rails?
Why?
Old Apr 24, 2014 | 12:09 PM
  #40
Regulator on the firewall
