Fuel pressure regulator goes on supply or return?
#61
There are many ways you can plumb the system and get fuel, how many times does that need repeated for you ?
Some ways are better than others. So where have I said it is "wrong" ?
I have clearly said it is not the ideal or best way to do it, especially without confirming fuel pressure.
But nowhere have I said it will not, or cannot work if implemented in a sensible manner.
And it certainly isnt new, ground breaking, lateral thinking, in or outside any boxes etc etc, because I have been running 2 of my 4 rails as dead ends for about 7 years.
But I know my fuel pressure is solid, because Ive checked.
That doesnt alter the fact dead end rails are less than ideal, especially if you dont understand what you're doing.
If you fully understand and are aware of the deficiencies of such a layout and plumb it with suitable fittings, rail diameter etc etc then it can of course work.
#62
No I completely get it. I'm just making a point that either way will work (something you've said also). I just want whoever might read this and not be as experienced as us to realize they have multiple ways to do it. The problem with LS1tech is that all too often, people say things can't or shouldn't be done, and then inexperienced people spend needless amounts of money.
I'm going to do it this way because One of my rails is close to the alternator and the 180* actually touches the back of the plastic on the alt. And my manifolds are flipped up and forward, so I'm going to feed them from the back and dead head the fronts. This alternative method is the best way for me to safely run my fuel system.
The new motor and turbo setup will make close to 1000FWHP, and I know this method will work fine, based on what others have already done successfully.
So is the phrase "less than optimum" true? In my opinion, no, not at all. It's not as good as the other way, but anything that can handle close to 800 wheel and not melt the motor down is perfectly optimum.
#63
Advising people who do not understand or have experience to work out problems etc, and telling them to do things which are less than ideal because you think it is generically ok, is a very very bad way to give advice.
#65
You guys are right. My next build will be a forged 370, Garrett turbos, pt4000, rule 3700, 25.5, fab 9", -12 feed y to two -10 at the rails, fpr after the rails (of course), belt drive fuel pump, rossler 2 speed th400, big stuff, racepack. Cheaping out anywhere or doing it a non traditional way will never work.
Boy, I'm glad I never listened to you guys when I built my car.
#66
Don't be a douche. You sound like an idiot.
I have had my regulator in the back of the car before. I obviously have done it both ways and have have gauges to view
I can tell you rail pressure stays much more stable in terms of pulsing at highoad and injector pulse widths when viewing. The sender voltage
BTW. How many engines have you blown up?
#69
I cant believe there is a 4 page thread on this. Stevie is right, I am an engineer by trade and it looks like he is too. FPR before the rails will absolutely work but I'd rather not leave my FPR blind to what its supposed to be regulating, ie the FP through the rails. Pressure is absolutely lost across the rails, especially at high loads and because there are flow restrictions in the system. While its probably not enough to grenade a motor, i'd rather just eliminate a potential hazard. Guess what? Routing the FPR before or after the rails costs EXACTLY the same amount of money.
Its a matter of preference and if the best way costs the exact same amount as a less "optimum" way, its a no brainer.
You guys are arguing symantics.
#70
This has been an entertaining read. Rotary hit it on the head with his first two comments in his last post. Because you have ran 9's Cameron, you are all the sudden the ******* man! I see it all over the internet now. Congrats!
FWIW, I have mine like you do Ryan. Also, I am using a cellulose 10 micron filter pre injectors, and my stock feed, which is now my return, still has the stock filter on it. I have had no issues and have inspected the filters as well.
#72
Thanks man!
#73
i have done a regulator before, after, and hitting one or both rails at the same time
also stock truck intake with the stock return regulator
and gone 9s on all of them without fuel issue.
just do what you want with what you got.
#74
#77
#78
I actually have seen high hp Subaru motors have the last cylinder on a series set up run leaner. Changed to parallel and it cleared up. Could very well have burnt out that piston. Series being where you have the crossover between cylinders instead of a feed for each side. Last cylinder in the chain was the one that ran lean.
#79
All those 90deg bends in the factory pipework between the rails cant help anything.
Would normally trim cyl3 and sometimes 4 ( both rears ) with a little more fuel just for safety
How much is rails and how much is other..hard to say.
#80
Ok so I bought a y black to feed each rail without connecting them in series. But my fuel pressure regulator only has 1 inlet and 3 outlets and 1 return. So how do I connect the rails to the regulator if I only have 1 inlet? Can I connect them to the outlet spots?
