Stock internals T76 build
T76 .96 A/R
50mm wastegate
50mm BOV
Truck manifolds
"317" heads with BTR titanium spring kit with LS9 head gaskets and ARP studs
Comp lifters or LS7 lifters? Ended up going with LS7 lifters.
LS6, TU1 or TU2 cam? Ended up going with BTR stage 2 turbo cam @ 226/231 .605"/.598" on a 113
Racetronix DIY dual pump kit
80lb injectors
E85
3 bar map
10psi
I would love to hear/see some of your guy's fuel setups. Pictured Is how the car is NA. How and where have you mounted your fuel pressure regulator? Also has anyone ran the DIY racetronix dual pump kit? Just wondering if anything else is needed with it. I'm thinking about buying http://www.racetronix.biz/customkiti...DIYDPK-F99&eq= this kit.
the abs at all. just pay attention ! also do some
good test braking in a parking lot to get it right.
