Converting 4 bolt heads??
Old May 16, 2014 | 05:34 PM
blackonblacksls's Avatar
Default Converting 4 bolt heads??
I know I have seen threads or posts about this before.
Anyone here done it? Or know of a Place that does?
I almost think the easiest thing to do would be to just build up alum where the tabs would be. And then drill and tap them before milling the head.
Bought aftermarket 4 bolt heads because was planning on using my ls7 block.
Well one thing led to another and now I am using a lsx block.
And hate to not use 6 bolt heads with it.
Getting new heads isn't an option because I already have the valve train planned out and heads already have jessel rockers.
Old May 16, 2014 | 06:03 PM
stevieturbo's Avatar
Sell 4 bolt, buy 6 bolt.
Job done.
You're wasting time, effort and money ******* about with any other route.
Old May 16, 2014 | 06:20 PM
lsx1's Avatar
I'm pretty sure LME can do it
Old May 16, 2014 | 09:37 PM
cmac06's Avatar
I called around about the same thing, and it was cheaper to just sell the heads and get six bolt heads. It's 100 more for most 6 bolt heads vs other world cost to convert 4 bolt heads. Even with machine work for rockers, you're still in it less to get new heads.
Old May 16, 2014 | 10:10 PM
To order new heads. With a comparable rocker system I would spend another 6k to 7k dollars.
So to say converting these would be wasting time, money, or cost the same as new heads is foolish.
Even if I spent 2k or 3k on converting these it would be better than buying a new set.
I also mentioned buying new heads was not an option. So no point in even bringing it up.
I have called LME twice and not got a phone call back yet.
If I hear from them I will see of they still offer it.
Old May 17, 2014 | 12:21 AM
Blown06's Avatar
8 Second Truck Club
You need to have your head checked!
Old May 17, 2014 | 11:49 AM
Rather spend 2k or 3k on these than 6k or 7k on new ones.
Even 4bolt I'm sure I can throw a ton of crap at these. But if it wasn't a huge deal to add the tabs I figure why not.
It's obviously possible and has been done by several people on lots of different heads.
Just wanted to see if anyone around had some insight or experience on it.
If lot I'll either figure it out myself or just not worry about it, depending on how quickly the shortblock goes together.
Old May 18, 2014 | 12:47 AM
Blown06's Avatar
8 Second Truck Club
There is not a 4-bolt head in existence that would justify spending an extra 2-3 thousand dollars on them would make any sense to put on a 6-bolt block.
I'm not sure that's worded how I want to say it, but you get the point.
Please break it down for me, the 6-7 thousand dollars to convert to a 6-bolt head.
Old May 18, 2014 | 06:47 AM
MUSTANGBRKR02's Avatar
I spent about 5k on my TFS 255's heads with crower shaft rockers, upgraded springs and cnc'd by LME. Unless you have some Mozez heads or something like that I don't see 6-7k.
Old May 18, 2014 | 09:17 AM
Call wcch, or Frankenstein and ask for a set of all pros, mast, or rhs loaded out for a solid roller with jessel rockers.
Trickflow doesn't make ls7 heads so that's not an option either.
Old May 18, 2014 | 10:17 AM
That's what I figured on what type you had. I know how much all of those go for.
Old May 19, 2014 | 01:38 AM
Blown06's Avatar
8 Second Truck Club
Okay, I didn't realize you were in "that" market.
Still, don't cut yourself short. Just save up some money, sell the stuff you have and bone up. You'll be glad you did in the long run.
Old May 19, 2014 | 02:27 AM
The problem is anything welded on will never be as strong as factory cast.
So you'll spend a lot of money adding them, they'll never be as good, and there's the chance they'll break off.
So all the money could be spent for nothing.
1/2" studs would probably be a more cost effective solution
Old May 19, 2014 | 06:00 AM
JAX04's Avatar
To add to this, i cannot remember if it was the block or heads, but i remember reading a thread on bullet where people were saying they tend to crack when the bottom ears are added.
Old May 19, 2014 | 05:00 PM
Firehawk441's Avatar
This is the correct answer as to why NOT to do it.
Old May 19, 2014 | 08:12 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
MAST sells some kickass heads that are 6-bolt, and not even close to 6k-7k.
