SBE Lq4 almost wins NMCA West True Street.
#45
Thanks guys! Correct class is limited to 8.50, as well as my cage. I have added a bit of weight to the car with bigger brakes, trailer hitch etc so 8.50's should be about right. Had planned on putting a hotter engine in the car but sold the new engine a few weeks ago so stocker is staying.
#49
Damn your in a heavy populated class. It'll be cool to met you in person though. I'll be in Super street Power adder in my turbo truck due to frame modifications. Bring plenty of parts and if your running E85 pre-plan fuel stations near the tracks.
#51
They have single Isky drop in valve springs, and minor porting. Stock valves, retainers etc.
#56
I sent you a PM,,,, THIS CAR ROCKS,,, I have your back if you want a x tra set of axles for drag week,, I have a set of 30 spline axles, moser, c clip eliminator with 3 inch 1/2 screw in studs just sitting around, I can lend you if ya need them, PM me back, I can text ya a picture of them,, they are for a 70 nova
#57
#59
Will be good to meet you on drag week. I'll be running a SBE L33 7876 on e85 in a white trans am. Only going for DD though since just got the car running and its still on a built 60e.
#60
I hear you! That's where I was last yr. I would have still given it a shot but was sold out. Hopefully I dnt break, or blow something up before! I put 200 miles and a few romps on car today in 100 deg heat.
