Red Rocket goes 4 digits!
Old May 27, 2014 | 09:28 PM
ta02zx10r's Avatar
Lol maybe we should talk then Martin. Although traction is already an issue without the low end
Old May 27, 2014 | 09:34 PM
01SSRMS's Avatar
Very nice! And gives me hope of hitting similar although my setup will be a 370 with ls3 top end and twin precision 66s. My goals are get it to 800 whp on 93 and then have the option of changing to e85 at some point and running more boost. E85 is available around here but scarce with only a few stations. That and this is my first build of this magnitude and figure that will be plenty to learn with. Really enjoyed your build thread and learned a lot from it. I have a Huron speed twin hot side kit so very similar. Congrats again!
Old May 27, 2014 | 09:54 PM
427zm's Avatar
Originally Posted by Martin@Tick
Glad to be a small part.
FWIW Josh tells me that the turbos are lit as soon as he rolls into the throttle. The smaller cam and the smaller AR housings really allow that to happen.
If the boost controller would hold boost to 7k Josh would of seen 1100rwhp unlocked through a 9" and full 3" exhaust.
Anyone wanting to replicate a more drag oriented version of this set-up could easily see another 100rwhp with 4" down pipes and larger AR housings.
Congrats Josh!
Nice numbers!
Martin going +6 on this cam! Nice! I thought going +5 on my cam spec last week was as far as he'd go.... guess not!
Old May 28, 2014 | 05:26 PM
V-10 Killer's Avatar
I'm curious, how hard were you pushing those injectors at that power level? And did you run 8AN line all the way from the pumps then. I was debating on doing 10AN, but this is already above where I'd ever want to be.
Old May 28, 2014 | 07:05 PM
I8UR4RD's Avatar
Im pulling my 8's now for 10's. dont have to. i know i will need to sooner or later.
Old May 29, 2014 | 06:30 PM
Sales@Tick's Avatar
Originally Posted by 427zm
Nice numbers!
6 degrees is normally the limit to still keep the heat treat happy.
The wider the split and the wider the LSA the touchier that gets.
Old Jun 1, 2014 | 03:10 PM
allout06's Avatar
Thanks for the kind words guys! im excited about it. We did a little more tweaking the other day. i swapped from 11psi WG springs to 15psi WG springs to help carry and hold the boost a little better and this was the result.
we bumped her up to about 26.5-27psi and added a degree of timing. runs really strong lol
also won me this
I had an SVT vs LSX competition on a dyno against another twin turbo cobra. he made 982 whp... lol
As far as some of the questions..
My fuel setup is twin walbro 450's with a -8feed 6return. the injectors are ID 1300s and theyre pretty well tapped at 108% IDC. fueling was still good though. 11.7AFR we could really lean it out a little more but we just left it.
The boost controller is an Eboost2. I think i have really high back pressure, and probably should switch to a controller than can utilize CO2
Old Jun 1, 2014 | 03:17 PM
JAX04's Avatar
Congrats man!
I wanted to make it down there yesterday but had a lot of things going on.
Glad to see she is running strong, and well done beating the mod motor
Old Jun 1, 2014 | 03:19 PM
stevieturbo's Avatar
Measure back pressure, then you'll know for sure.
If the controller is working and covering all boost options, then I see no reason to use CO2.
Going well though !
Old Jun 1, 2014 | 03:26 PM
Sales@Tick's Avatar
Great job on the dyno competition win Josh!
Time to go 8's @160!
Old Jun 1, 2014 | 08:42 PM
Cam72aro's Avatar
Congrats Josh. What did the final timing number end up being? 1105 to the tires through a 4l80 is insane. This was unlocked, right?
Old Jun 1, 2014 | 08:45 PM
  #32
Superman09's Avatar
LS1Tech Sponsor
Awesome Josh, also glad to be a part of this! Told you those turbos would do exactly what you wanted for your goals! Keep it up and keep enjoying!!!
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jun 2, 2014 | 02:42 AM
  #33
MUSTANGBRKR02's Avatar
Sick numbers!
Old Jun 2, 2014 | 10:34 AM
  #34
ls1curt's Avatar
Nice numbers.
1100rwhp unlocked should go 170 easy.
Old Jun 2, 2014 | 01:46 PM
  #35
Sales@Tick's Avatar
Originally Posted by ls1curt
Nice numbers.
I was more or less saying 8's@160 will be the norm for his car. Not that it would never run faster than 160. 160,165 or maybe 170...it will be up to Josh where it stops and ends up.
I don't think Josh's car has any weight reduction done to it and on top of that it has an iron block, twin turbo's, 4l80e and an intercooler.
That's an additional 200lbs.+ on top of a 3500lbs car.
3700 lbs and 1100rwhp unlocked should go 160+, but I don't think 170 is going to happen.
Old Jun 2, 2014 | 05:14 PM
  #36
AES Racing's Avatar
Great Job!
Old Jun 26, 2014 | 06:02 AM
  #37
JAX04's Avatar
Any updates man? how is she holding together?
Old Jun 26, 2014 | 08:21 AM
  #38
Blackpanther99's Avatar
Congrats man!
Old Jun 29, 2014 | 06:53 PM
  #39
Tirefire's Avatar
What callies crank is in there?
Old Jun 29, 2014 | 08:59 PM
  #40
Camaro9969's Avatar
Great numbers curious what it will do at the track will dip well into the 8s even with that weight.
