Spark plug recommendation
Old May 30, 2014 | 06:10 PM
97_C5's Avatar
Default Spark plug recommendation
Ok so I have a 370, vengeance racing tfs fast as cast 220's, with a s480 88mm on e85. I'm looking for input on what spark plugs/heat range to start out with. Any info is greatly appreciated. Thanks
Old May 30, 2014 | 08:13 PM
Wicked69's Avatar
I run the AR3934's and love them. I run twin S366's on E85 and 22lbs of boost gapped at .022. Tons of street driving and track passes with some 5.60's in the 1/8th. No problems and I run E85. It would be a good starting point and then you could read the plugs.
Old May 31, 2014 | 12:31 PM
97_C5's Avatar
Alright thanks for the recommendation
Old May 31, 2014 | 01:21 PM
RonSSNova's Avatar
Non resistor right?
I thought that was a no no? Maybe your Holley setup doesn't care Del?
Ron
Old Jun 2, 2014 | 03:04 PM
97_C5's Avatar
So will I be safe with that running a stock ECM setup running hp tuners
