Twin Garrett's suitable for 403 ls2...
Old Jun 8, 2014 | 10:53 AM
Mel Carlson's Avatar
Hey buddy... which turbonetics 66's do you have? what kind of power are you seeing? text me sometime if you don't mind. 8607192116
Old Jun 8, 2014 | 11:27 AM
oscs's Avatar
No power results yet, still waiting for the motor. I went with the 66/64's for my 370ci build. I believe there is a guy on here who made around 1100 with the same turbos. I used forced inductions but Huron speed was actually cheaper by $100 or so. These particular small frame turbos have a few blade sizes. I would contact either one of those companies and see what the largest MM you can go with in that frame.
I paid right around $1450 shipped for both of them and they are small.. They where almost identical in size to my master power T61 turbos.
Old Jun 8, 2014 | 11:53 AM
Cool I appreciate it... so you're actually using a compressor housing smaller than the 'TC' series?
Old Jun 8, 2014 | 11:57 AM
stevieturbo's Avatar
Originally Posted by RonA
If you had plenty of room in the engine compartment between the radiator and the motor, would you still have gone with twins?
I have zero room there.
My car is not a drag car, it's also manual. So spool, transient response etc etc are all very important.
I did seriously consider a big single, mainly from a cost perspective. But there would be no way to achieve it with a sensible downpipe.
The low mounted twins actually worked out a lot better than I had expected. Manifolds are compact, truck based. Downpipe is almost a straight shot out, I actually have more ground clearance than my previous 2" headers/collector
It was all a win win really. A big single even if there had of been room....would probably have been more complicated overall...even if in theory it should be more simple.
Old Jun 8, 2014 | 12:12 PM
oscs's Avatar
That's a damn good question.. I called FI and told them i wanted a turbo the exact same size as the Master Power T61. The turbonetics was suggested and damn near identical in size. Although my S/N begins with a "T" i have a feeling they are in the 60 series as apposed to the "T" series. Ill find out tomorrow for sure though.
Old Jun 11, 2014 | 11:11 AM
oscs's Avatar
Talked to FI today. The 60 series is what I have and let me tell you they are very compact. The guy at FI said you can go as large as 76mm in the frame. That is unreal to me becuase these turbos are not big at all. My BW S366 is much larger.
