gauge install help
Couple questions I have...yes I've searched like crazy but few little things I never got from other threads
First: I plan on running the wideband wiring through the gromet under the seat. Buty question is once I get it up there...how are people running wires to under the dash. Do I pull up the carpet and run it under there? Or am I supposed to lift the center counsel and run in that? I'm just looking to get a clean install...its an automatic.
Second: for the boost gauge and bypass valve...I plan on running them out of the brake booster hose. What type of fittings do I need to split that off? Looks like the brake hose is maybe 1/2"(? Or 5/8"?) Then I have to split into the tiny boost gauge tube that came with the gauge.. also getting the 3/16 vacuum hose attached for the bpv.
Any help and PICS would be great! Thanks a lot guys!
Wow! That is an amazing thread/build in general! Thanks for sharing that. Those guys really take that stuff serious. Wish more shops were that caring and thoughtful when doing work on cars.
